First post, by Jef
Today, I grabbed the latest DOSBox source (2009-01-14), installed SDL, SDL Net, SDL Sound, Libpng & Libz. Compiled DOSBox but I wanted to have static libraries so I followed this guide : http://www.spam-filter.de/dosbox/dosbox_0.65_for_intel_macs
I changed some file locations so they were correct on my Mac and then the error pops up
It's like :
Undefined symbols:
"GUI::Window::keyDown(GUI::Key const&)", referenced from:
vtable for ConfigurationWindowin libgui.a(sdl_gui.o)
vtable for AutoexecEditorin libgui.a(sdl_gui.o)
vtable for GUI::TransientWindowin libgui.a(sdl_gui.o)
vtable for SectionEditorin libgui.a(sdl_gui.o)
<same errors till the end>
SaveLangDialog::SaveLangDialog(GUI::Screen*, int, int, char const*)in libgui.a(sdl_gui.o)
ConfigurationWindow::actionExecuted(GUI::ActionEventSource*, GUI::String const&) in libgui.a(sdl_gui.o)
"_MIDIClientCreate", referenced from:
MidiHandler_coremidi::Open(char const*)in libgui.a(midi.o)
ld: symbol(s) not found
collect2: ld returned 1 exit status
For those who want to see the full error, download the attached .txt file...
Can someone help me with this ? thanks
    Error Log.txt
    24.39 KiB
    202 downloads
    The error log
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
did you use the
g++ -g -O2 -o dosbox dosbox.o cpu/libcpu.a debug/libdebug.a dos/libdos.a \
fpu/libfpu.a hardware/libhardware.a gui/libgui.a ints/libints.a \
misc/libmisc.a shell/libshell.a hardware/serialport/libserial.a \
/opt/local/lib/libSDL_mixer.a \
/opt/local/lib/libSDL_sound.a \
/opt/local/lib/libSDL_net.a \
/opt/local/lib/libmikmod.a \
/opt/local/lib/libmp3lame.a \
/opt/local/lib/libsmpeg.a \
/opt/local/lib/libvorbisenc.a \
/opt/local/lib/libvorbisfile.a \
/opt/local/lib/libvorbis.a \
/opt/local/lib/libogg.a \
/opt/local/lib/libpng.a \
/opt/local/lib/libz.a \
/opt/local/lib/libSDL.a \
/opt/local/lib/libSDLmain.a \
-framework OpenGL \
-framework QuickTime \
-framework AudioUnit \
-framework IOKit \
-framework Cocoa \
-framework Carbon \
-lm
Posted on that website ?
As that isn't correct for 0.72cvs (the instructions there are for 0.65
You will need to add a few lines to it.
one thing is you need to add:
libs/gui_tk/libgui_tk.a
(to the top after libserial.a
and probably these to the end
 -framework CoreMidi -framework AudioUnit -framework AudioToolbox
but really don't use instructions for an old version when compiling the new version.
Water flows down the stream
Reply 2 of 2, by Jef
UPDATE It works now, I accedentally used the oldest SDL_sound and not the newest. Thanks Qbix!
Yes indeed I used that list but I modified it a bit and now I've added your stuff and it looks like this :
  • g++ -g -O2 -o dosbox dosbox.o cpu/libcpu.a debug/libdebug.a dos/libdos.a \
    misc/libmisc.a shell/libshell.a hardware/serialport/libserial.a libs/gui_tk/libgui_tk.a \
    /usr/local/lib/libSDL_sound.a \
    /usr/local/lib/libSDL_net.a \
    /usr/local/lib/libpng.a \
    /usr/local/lib/libz.a \
    /usr/local/lib/libSDL.a \
    /usr/local/lib/libSDLmain.a \
    -framework OpenGL \
    -framework IOKit \
    -framework Cocoa \
    -framework Carbon \
    -framework CoreMidi \
    -framework AudioToolbox \
    -lm
This still gives an error but it's massively smaller, here's the full errror :
Undefined symbols:
"_Sound_Seek", referenced from:
CDROM_Interface_Image::AudioFile::read(unsigned char*, int, int)in libdos.a(cdrom_image.o)
CDROM_Interface_Image::AudioFile::getLength() in libdos.a(cdrom_image.o)
[/b]
