First post, by The Merg
I am using DosBox v0.72 and am trying to run Twilight 2000. It seems to be working fine except that it does not recognize my mouse. I tried to lock the mouse in the window using Ctrl-F10, but that still did not work.
I have a Dell Dimension 4600 running Windows XP-SP3. My mouse is a Microsoft Optical connected via a PS/2 connection. Is there a mouse driver that I need to install in DosBox? I did not see anything about that in the README and FAQs.
Any help would be appreciated.
- Merg
Today's problems don't worry me,
I haven't solved yesterday's yet.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
try the cvs of DOSBox
http://builds.tharos-online.de/
if that doesn't work you are out of luck until we debug this game to see why it doesn't detect our mousedriver.
However I have good hopes for the CVS.
Water flows down the stream
Reply 2 of 4, by The Merg
Tried the CVS for 01/25/2009 and it still didn't work. I also noticed that I am not getting sound/music for it as well as for 7 Cities of Gold.
I do have use of the mouse and sound for Auto Duel though.
Thanks for the quick reply.
- Merg
Reply 3 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Mouse and sound are working for me in 0.72; however, they both have to be configured in the game's setup before they will work. i.e. "MOUSE: YES" and "SOUND: CMS SOUND BLASTER IO:220 DMA:1 IRQ:7"
Reply 4 of 4, by The Merg
That did the trick. I just assumed that the install file was a remnant of actually installing the game. I forgot that some old DOS programs used INSTALL as way to setup the game.
Working fine now.
Thanks for the help.
- Merg
