First post, by DosFreak
http://www.newegg.com/Product/Product.aspx?It … 44&Tpk=WD20EADS
$299
Model
Brand Western Digital
Model WD20EADS
Performance
Interface SATA 3.0Gb/s
Capacity 2TB
RPM 7200 RPM
Cache 32MB
Physical Spec
Form Factor 3.5"
/Koolaid Guy Oh yeah.
Make your games work offline
Reply 1 of 6, by 5u3
€ 220
3 years warranty
And no more flashing those Seagate Barracudas... Yay! 🙄
Reply 2 of 6, by valnar
How many FAT16 2GB partitions is that?
Reply 3 of 6, by Xian97
I recently got a 1 TB Western Digital drive with money I got for Christmas. I have used Seagate for years, but with their recent firmware problems I wasn't wanting to take a chance. I have had WD drives in the past and had good luck with them.
The only downside is that a 2 TB drive is going to take a long, long time to format. My 1 TB took over 3 hours. I always do a full format on a new drive so that every sector is tested. Any later formats I just do a quick format, but the initial time I always do full.
Reply 4 of 6, by Harekiet
Rank DOSBox Author
DOSBox Author
When you put these things in a raid array the chances of another drive failing while you're restoring the array just keeps getting bigger. Scary 😀
Reply 5 of 6, by DosFreak
Just use RAID 6 and have a good backup (ESATA External HD's for "quick" restore) and you should be good to go.
I have 6 1TB drives in my home server using RAID 5 but when I replace them all with 2TB drives I'll probably be going to RAID 6.
Reply 6 of 6, by doomer
Sweet drives. 😁
