New 486 rig assembled *Updated, again*
First post, by Amigaz
(Think 😀 ) I have settled with just two socket 3 systems and this is one of them...since you guys bullied me for using a Cx5x86 in my last buold I'm using a cpu you can't nag on me for using 😉
Ok, here's the spec's:
Mobo: Gigabyte GA 486TA
8 Eisa slots, 2 of them have VLB slots
20mb RAM
CPU: Evergreen 586 upgrade (am5x86 133mhz)
I/O :
Adaptec AHA 2742W Wide Eisa SCSI controller [i][color=green]*NEW*[/color][/i]
Simple Goldstar chipset I/O card with only COM1 active for
mouse support
[b][u]Storage[/u][/b] : Maxtor 18gig 15k RPM SCA SCSI disk
Pioneer 12x SCSI CD-ROM
1.44 Floppy drive, 5.25 1.2mb Floppy drive
[b][u]Graphics[/u][/b]: Diamond 64 DRAM VLB [i][color=green]*NEW*[/color][/i]
[b][u]Sound[/u][/b]: Sound Blaster AWE32 CT3900 + Nec Yamaha DX60XG clone [i][color=green]NEW[/color][/i]
Gravis Ultrasound PnP rev 3, Ensoniq Soundscape Elite, Roland Super MPU,
Roland MT32, Roland CM-500
Everything housed in a Vobis Hisgscreen Colani tower
[url=http://www.imagebam.com/image/bdf55f25258091][img]http://thumbnails15.imagebam.com/2526/bdf55f25258091.gif[/img][/url]
[url=http://www.imagebam.com/image/b66bbd25258094][img]http://thumbnails15.imagebam.com/2526/b66bbd25258094.gif[/img][/url]
[url=http://www.imagebam.com/image/2d16e725258092][img]http://thumbnails4.imagebam.com/2526/2d16e725258092.gif[/img][/url]
[u]
[b][u]Planned upgrades/mods[/u][/b]:
Max out RAM to 128mb with 8x 16mb 30pin sticks
Connect speaker output to speaker input on the SB16
Add my Adlib Gold in the vacant Eisa/Isa slot...if it doesn't work I'll
throw in a 3Com Eisa 10mbit NIC in there
[/u]
Reply 1 of 67, by swaaye
🤣 look at how bent that poor Ensoniq card is! Maybe after time it'll return to it's natural shape....
That is one tricked out 486 there. If it works, it's truly amazing.
An interesting Am5x86 you have too. Does that board need a upgrade version of it because of a lack of 3.3v support?
Reply 2 of 67, by Amigaz
yeah, it's amazing it works with that bent in it...I think the reverb DB saved it from taking a fatal bend
The board is from early 1993 so it's only 5V....I first tried a regular am5x86 with a VRM adapter but I got terrible performance and never got it running at 4x33mhz = 133mhz...even by fiddling with the jumper on the VRM adapter (2x, 3x modes) so I guess this Evergreen thingie has some "magic" in it
Reply 3 of 67, by Anonymous Coward
Your 486 system is looking very similar to mine these days. I have exactly the same DB60XG board also on an SB16 (only CT1770).
I think it's interesting you had troubles getting a real 5x86 chip going in there. I've had problems with the Cyrix chips, but the AMD 5x86 is usually trouble free. I actually tried that same evergreen 5x86 chip you are running in yours, only mine gave me NMI timer errors. Maybe it's defective?
Reply 4 of 67, by prophase_j
Also be careful with those SCA-68pin adapters. If you strain the little board from the top toward the drive the solder points from the molex power connector can come into contact with the today of the hard drive! I Burned out two disks one time before I figured out what was happening. I urge you to inspect this detail to see if your setup is suspect as well. Problem was all but eliminated with a carefully cut piece of pizza box made to act like shim
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 5 of 67, by Amigaz
I think it's weird that the 2x/3x jumper on the VRM adapter didn't make the CPU run at 133mhz...according to both Norton SI and speedsys it ran at 100mhz and the system fel very sluggish like the cache was turned off ir something.
Tried your evergreen CPU in another system?
btw. still waiting for a pic of what your Eisa system looks like when it's up and running 😉
Reply 6 of 67, by Amigaz
I've had this adapter for some time..first used it in a dual PIII system I bought..the previous owner had put a piece of electrical insulating tape so it can'nt short..that piece is still there 😀
The 15k rpm drive really makes a difference..the system boot much quicker compared to for example a 7200 rpm drive and moving files between partitions goes lightning fast! 😮
Reply 7 of 67, by retro games 100
<retro games tries an old Jedi mind trick>
You don't need this machine any more...
You will hand it over to me...
Reply 9 of 67, by Amigaz
But it's a bit noisy, isn't it?
Nope 😀 these "newer" drives are very silent..this one is from 2002
I have two other 18gig 15k rpm and a 146hig 15k rpm drive and they are very silent.
But the 10k rpm drives I own tend to have a whining noise
Reply 10 of 67, by Amigaz
retro games 100 wrote:
<retro games tries an old Jedi mind trick> […]
har-har!
Jedi mindtricks don't work on me!
Reply 11 of 67, by Malik
wrote: <retro games tries an old Jedi mind trick> […]
har-har!
Let me try that in a different form...
Need this machine any more,You don't...
Hand it over to me,You will .
Reply 12 of 67, by retro games 100
Reply 13 of 67, by WolverineDK
Amigaz, that is one if of the coolest and most awesome looking 486 setups I have seen. Wow that is one fucking awesome machine, thumps up mate 😀 😁
Reply 14 of 67, by keropi
I never seen this cpu upgrade... my 5x86/133mhz is a normal brown ceramic chip... does yours have a voltage regulator onboard amigo?
Reply 15 of 67, by Moogle!
The Evergreens do, yes, and as far as I know, they work in any LIF socket, such as my Compaq deskpro. The cache supports both write back and write through, though regardless of it's onbaord jumper setting, will only do write back in a write back support system. The board the Evergreen is used must be jumpered/switched to to be in Intel DX2, with the DX2/DX4 jumper set in DX2 on both the board AND the Evergreen.
Reply 16 of 67, by Amigaz
Yep, everything is built into the base of this thing 😀
Reply 17 of 67, by Amigaz
Malik wrote:
Let me try that in a different form... […]
har-har!
No Yoda Hocus Pocus bites on the the might Jabba The Hut! 😎
Reply 18 of 67, by swaaye
BTW, Amigaz, if you wanna use Cx5x86, don't let us stop you. I have one myself. It's an interesting chip but it's just not as fast as a 160 Mhz Am5x86. And it may have compatibility probs but I am not sure on that. I know it's not Pentium-compatible (neither is Am5x86), but not sure about its 486 and older compatibility.
Reply 19 of 67, by Anonymous Coward
I have yet to get a cx5x86 working in 5V only socket3 systems using the appropriate adapters.
