First post, by gmailtae
Tried getting this message when running wonder~1 or wg.exe from dosbox.
It's also just the same experience when you've typed in echo You aren't also in January???.
These are just the supported characters in the Cyrillic version of Albertus. The supported characters were: Ё-Ќ, Ў-я, ё-ќ, ў, џ, Ґ, ґ. Unsupported is Greek characters. You try downloading an ASCII font. The letter j is modified in ASCII VGA, the question and the letter s is modified in ASCII VGA, Peseta and yen also modified, the small n tilde was modified.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
you are running a windows program in a dos emulator.
Water flows down the stream
