DosBox en Bat??
First post, by netolk
Hi there, I has maked a Menu in Bat. When I try to run it in DOSBOX it jams. Can Anybody tell me why?
this is the code
@ECHO off
cls
:start
ECHO.
ECHO.
ECHO 1.Lemmings
ECHO.
ECHO 2.Pacman
ECHO.
ECHO 3.Prehistorik
ECHO.
ECHO 4.Prehistorik2
ECHO.
ECHO 5.Exit
ECHO.
set choice=
set /p choice=Type the number to print text.
if not '%choice%'=='' set choice=%choice:~0,1%
if '%choice%'=='1' goto Lemmings
if '%choice%'=='2' goto Pacman
if '%choice%'=='3' goto Prehistorik
if '%choice%'=='4' goto Prehistorik2
if '%choice%'=='5' goto Exit
ECHO "%choice%" is not valid please try again
ECHO.
goto start
:Lemmings
cd Lemmings
lemvga.com
cd ..
Menu.bat
goto end
:Pacman
cd pacman
pacpc2.exe
cd ..
Menu.bat
goto end
:Prehistorik
cd prehistorik
historik.exe
cd..
Menu.bat
goto end
:Prehistorik2
cd prehistorik2
pre2.exe
cd..
menu.bat
goto end
:Exit
exit
goto end
:end
grtz. netolk
Reply 2 of 20, by MiniMax
Rank Moderator
Moderator
It is because of that
@ECHO off
at the start. Remove it and you will see what is wrong.
_________________
Reply 5 of 20, by ADDiCT
Remove the "set /p" stuff and use something like CHOICE.COM or 4DOS?
You can develop a _real_ menu system with WBAT. I've created a full-blown menu system with all my installed DOS games, and it looks terrific. It's quite a bit of work, though.
Reply 9 of 20, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The CHOICE command is built into DOSBox, no need to use an external program.
choice /N /C:12345 Type the number to print text.
if errorlevel 5 goto Exit
if errorlevel 4 goto Prehistorik2
if errorlevel 3 goto Prehistorik
if errorlevel 2 goto Pacman
if errorlevel 1 goto Lemmings
It is important to test ERRORLEVEL in descending order for something like this because lower levels test TRUE compared to higher levels.
Reply 15 of 20, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It should work. You're probably not doing it correctly.
choice /N /C:ABCDEFGHIJKLM Type the letter to print text.
if errorlevel 13 goto label13
if errorlevel 12 goto label12
if errorlevel 1 goto label1
I used the ellipsis there because I didn't want to type all 13 of them. Did you try to use "errorlevel A"? The ERRORLEVEL is a number, and in the case of the CHOICE command, it corresponds to the number of the choice in the list of possible choices.
However, if you are using this batch as a game launcher, you really will find using a frontend much more capable and accommodating.
Reply 16 of 20, by gidierre
ripsaw8080 wrote:
Same behavior in MS-DOS; apparently it is a less-than-or-equal-to comparison.
actually
if errolevel 1
has always coincided with
greater-or-equal-to 1
and not less-than-or-equal-to
in fact if one should write
if errorlevel 0 goto :zero
if errolevel 1 goto :one
that wouldn't do because with errorlevel==1 it would goto :zero as well
IOW if error level 0 always rings TRUE
or, it would have to read
if not errorlevel 1 goto :zero
for it to be correct IMO.
I don't think that would work either.
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 17 of 20, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Please don't confuse the issue. It's simply a matter of which terms you place on which side of the equation. It's less than or equal if you're comparing the test value in the batch file to the actual level value in DOS.
In other words: "if the errorlevel is at least <some number> then <do something>"
I used the "errorlevel A" to ask if that was the mistake that was made, obviously it won't work because it's a numeric value.
Reply 18 of 20, by gidierre
OK, then, obviously I must have gotten your statement wrong, as if it were somewhat problematic,
but I was just knee-jerk reacting along the old guideline to reassert that between errorlevel and n
a '>=' mark must be always seen etc.
I don't want to confuse any issues 😦
