Duke Caribbean: Life's a Beach Runetime Error
General information and assistance with DOSBox.
Postby ChilledMonkeyBrains » 2009-2-20 @ 14:26
I installed the GAMER software, activated the addon pack to its own copy of Duke Nukem 3D Atomic, and it seemed to work fine. But when I go to CARIB.exe and try to play a game, I get this message:
"runtime error 003 at 0000:0c88"
What do i need to do to get this game to work?
ChilledMonkeyBrains
Re: Duke Caribbean: Life's a Beach Runetime Error
Postby Qbix » 2009-2-20 @ 14:41
error 3 = path not found.
Did you mount everything correctly ?
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby ChilledMonkeyBrains » 2009-2-20 @ 14:58
I mounted the install drive for Caribbean as a cd-rom drive, if that's what you mean.
ChilledMonkeyBrains
Postby Qbix » 2009-2-20 @ 15:00
it's a bit vague.
please post the exact command you type to run the game. (and the command you used to install the addon (which you ofcourse did inside dosbox))
User avatar
Qbix
DOSBox Author
Postby ChilledMonkeyBrains » 2009-2-20 @ 15:14
INSTALL:
E:\CARIBBEA\install
(already had GAMER installed for Duke it out in D.C.)
C:\GAMER
GAMER
(activated the Life's a Beach add-on to a seperate copy of Duke Nukem ATOMIC from Duke it out in D.C.)
C:\CARIBBEA (where I have the Life's a Beach add-on going)
CARIB
Then I get the runtime error.
ChilledMonkeyBrains
Postby wd » 2009-2-20 @ 15:29
Please post the mountings and the exact steps how you installed/ran it.
Things like
INSTALL:
E:\CARIBBEA\install
are completely useless.
wd
DOSBox Author
Postby ChilledMonkeyBrains » 2009-2-20 @ 15:50
Lines in AUTOEXEC section of DOSBox.conf
MOUNT C C:\dosgames
MOUNT D D:\ -t cdrom
MOUNT E C:\test\CARIBBEA -t cdrom
C:
SD (I have StupenDOS 3.0 installed in DOSBox. It works.)
started DOSBOX
E:\CARIBBEA\install.exe
GAMER Software was detected.
A copy of Duke Nukem 3d ATOMIC detected in C:\ CARIBBEA
This is the copy of Duke Nukem I used for Life's a Beach.
Add-on pack installed.
C:\GAMER\GAMER.EXE
Activated Life's a Beach Add-on.
C:\CARIBBEA\CARIB.EXE
Selected Single Player from the Menu that appears.
Runtime error 003 at 0000:0c88
ChilledMonkeyBrains
Postby wd » 2009-2-20 @ 16:42
use "cd xyz" to change to a directory before executing an .exe file
wd
DOSBox Author
Postby ChilledMonkeyBrains » 2009-2-20 @ 17:08
Tried that; I still get the error
ChilledMonkeyBrains
Postby ChilledMonkeyBrains » 2009-2-20 @ 19:26
I take it then by your silence that there's nothing I can do...?
ChilledMonkeyBrains
Postby wd » 2009-2-20 @ 19:34
2 hours of no reply is silence wtf?
wd
DOSBox Author
Postby Qbix » 2009-2-20 @ 19:34
well install duke and both addons from within dosbox and use the same mounting to run them.
I don't own the expansions I only have the atomic edition, so I can't advice futher.
User avatar
Qbix
DOSBox Author
Postby SKARDAVNELNATE » 2009-3-23 @ 01:44
I just got Caribbean and I'm having the same problem.
Set up Duke3D in DOSBox
Set up Caribbean Vacation in DOSBox
Run CARIB.EXE
select either Single Player or Multiplayer
The strange thing about this is that if I double click on CARIB.EXE it runs in Windows XP. I also noticed that it created 10 files when it successfully launched. These look like MRK, NOÂ¥, OMÂ¥, SCP, and GRP. These are then deleted when it exits. I copied these files while it was running and added them before launching the game in DOSBox. This time it worked. I don't think DOSBox is allowing for these files to be created.
Edit 1:
It doesn't work entirely. I'm now shooting aliens in Hawaiian shirts with a water pistol only I'm not able to load the new levels. Though it is a clue as to what the error message means.
Edit 2:
Thinking the additional files might be backups of ones that have been edited I copied the full DUKE3D folder while Carribean was running in WinXP. Unlike Duke DC this one goes back to the normal game without disabling it in Gamer. Now when I launch the copy in DOSBox I get everything I expected. One side note. To work in WinXP DUKE3D.CFG needed BlasterInterrupt = 5, in DOSBox it should be BlasterInterrupt = 7. This can be changed in setup or edited manually.
User avatar
SKARDAVNELNATE
Postby Qbix » 2009-3-23 @ 07:12
errorcode 3: path not found. Are you sure that the mount points are the same as when you installed the game ?
User avatar
Qbix
DOSBox Author
Postby SKARDAVNELNATE » 2009-3-23 @ 13:07
Yes, as I got it working. Please read on.
I launched the game in WinXP and noticed that 10 files were created. This didn't happen when run in DOSBox. When Caribbean exits these files are removed. One of these was VACATION.GRP. When I copied this I no longer got the error. So it must have been looking for the path to VACATION.GRP.
However this only changed the weapons and aliens. I had to copy the complete folder to include files that were edited. This is where it's failing in DOSBox. CARIB.EXE doesn't make the changes to the game directory.
Edit:
I found that if I want to back up my game folder with a zip file I have to do so without compression. If I compress then extract I get the error message again. If I had compression set to none when zipped I can still play after extracting.
User avatar
SKARDAVNELNATE
Postby ChilledMonkeyBrains » 2009-3-23 @ 15:10
I tried copying the directory with the edited files but XP said it couldn't read from the source file or disk.
ChilledMonkeyBrains
Postby SKARDAVNELNATE » 2009-3-23 @ 16:01
Not sure what would cause that. Did you Copy/Paste or drag it? Drag would be Cut/Paste and since it's running it needs to stay in the same location.
User avatar
SKARDAVNELNATE
Postby ChilledMonkeyBrains » 2009-3-25 @ 13:53
It still won't work. Could I possibly get these edited files, either from you or another source?
ChilledMonkeyBrains
Postby SKARDAVNELNATE » 2009-3-25 @ 19:40
You could try copying one file at a time. It may be just one file you're unable to read and not the whole folder. I'm not sure what the forum rules are about providing them. I wouldn't think it's an issue since you already have them, just not in a state that works with DOSBox. Though I have been wrong before. Also since it runs in WinXP you could just play it like that and see if any errors occur.
User avatar
SKARDAVNELNATE
Postby ChilledMonkeyBrains » 2009-3-26 @ 16:23
tried the files, but they don't work.
ChilledMonkeyBrains
Next
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 3 guests
