Duke Caribbean: Life's a Beach Runetime Error
Reply 20 of 36, by Wizardling
Happens to me too using Boxer 1.0.2 (based on DOSBox 0.74) in OSX 10.6.7 🙁
Has anyone found a way to get Duke Caribbean: Life's A Beach running in DOSBox yet, without having to use Windows? It installs ok, GAMER.EXE runs ok and says it's enabled the addon, but running CARIB.EXE results in the same runtime error every single time 🙁
Frog blast the vent core!
Reply 23 of 36, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The CARIB.EXE addon launcher renames original files with an unusual character that DOSBox does not allow. For example, GAME.CON is renamed to GAME.CO¥ and GAME.NOC (the addon file) is renamed to GAME.CON, so the addon file is used by the game engine instead of the original file. The addon launcher also renames files back the way they were when doing a normal exit from the game.
There are various things you can do manually to work around the problem, but the addon launcher works correctly by itself if 0x9d (the Yen symbol in extended ASCII) is added to the list of allowed characters in DOS_MakeName().
Reply 25 of 36, by Wizardling
DosFreak wrote:
I thought eduke32 worked fine on OSX?
Well, I'm sure it does. But I kinda like running DOS apps in DOS where commandline switches and various classic content still works as it used to 😀
However if all else fails, how would I go about using eduke32 with this addon that seems to require file system access?
Reply 26 of 36, by Wizardling
How specifically do I do this, please? 😀 Thanks for your help, and that of the DOSBox devs - awesome emulator I couldn't live without nowadays.
Reply 27 of 36, by ripsaw8080
Rank DOSBox Author
DOSBox Author
As a temporary workaround for DOSBox 0.74, the attached patch program will modify the addon launcher in memory to use a Dollar sign instead of a Yen sign when renaming files. Put it in the game folder and run it instead of CARIB.EXE. You should re-install Duke3D and the addon in case the filenames are messed up.
I have tested the patch with Duke3D v1.3D and v1.5 (Atomic), but I'm not sure if there's more than one version of the Caribbean addon. The version of the addon installer (Gamer) that I have is v1.01. If your version of the addon is different the patch will probably not work.
    CARIBFIX.ZIP
    820 Bytes
    1342 downloads
Reply 35 of 36, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Seems as if it is already in SVN of dosbox, so, yes, next version of dosbox will have it
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
