First post, by CarlosG
Hi all, i have a game called Wing Nuts from Rocket Science Games that runs only from cdrom and when i execute setup.exe it just create a directory on drive C: and saves a .ini file in there. I'm new with DOSBox and i dont know how to configurate it, somebody could give me a hand?
Thanks is advance.
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 2 of 5, by CarlosG
These are the configurations i did:
mount d d:\ -t cdrom
mount c c:\Teste
setup.exe: runs well
wingnuts.exe: Fatal error: clock malfunction in disk calibration
mount d d:\ -t cdrom -usecd 0
mount c c:\Teste
wingnuts.exe:
DOS/4GW error (2002): transfer stack overflow on interrupt 08h at 80:000006C9
TSF32: prev_tsf32 3438
SS 98 DS 98 ES 98 FS 0 GS 8
EAX 3438 EBX 200098 ECX 0 EDX 1BA8A4
ESI 3332 EDI 338A EBP 3350 ESP 3338
CS:IP 80:000006C9 ID 08 COD 0 FLG 200202
CS= 80, USE16, byte granular, limit B88F, base 14C2A0, acc 9A
SS= 98, USE16, byte granular, limit 7CFF, base 157C60, acc 92
DS= 98, USE16, byte granular, limit 7CFF, base 157C60, acc 92
ES= 98, USE16, byte granular, limit 7CFF, base 157C60, acc 92
FS= 0, USE16, byte granular, limit 0, base 14, acc 0
GS= 8, USE16, byte granular, limit 3FFF, base 114010, acc 92
CR0: PG:0 ET:0 TS:0 EM:0 MP:0 PE:1 CR2: 0 CR3: 0
Crash address (unrelocated) = 3:000006C9
mount d d:\ -t cdrom -usecd 0 -ioctl
mount c c:\Teste
wingnuts.exe:
DOS/4GW error (2002): transfer stack overflow on interrupt 08h at 80:00000C46
TSF32: prev_tsf32 32D0
SS B0 DS 98 ES 98 FS 0 GS 8
EAX 0 EBX 200202 ECX 0 EDX 98
ESI 32D0 EDI 33A0 EBP 3296 ESP 3272
CS:IP 80:00000C46 ID 08 COD 0 FLG 200246
SS= B0, USE32, byte granular, limit 7CFF, base 157C60, acc 4092
Crash address (unrelocated) = 3:00000C46
In the last 2 configurations the errors may vary, causing sometimes the same as 1st exemple.
Reply 3 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If you try with fixed cycles you will probably get rid of this but in the past there have been posts about rocket science games not working with the error message "cdrom thread went to sleep".
1+1=10
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
Only setup.exe ? No install.exe ?
_________________
Reply 5 of 5, by CarlosG
Thx for the replys guys and what i get to the cycles and it's just setup.
