First post, by kicker04
Hi!
Is it possible to get Sherlock Holmes 2 running under Dosbox? I could install it but it always crashes after 10 seconds at the beginning. I added a screenshot as attachment. Do I need to set up some special configurations for that game?
Thanks for help!
    289.13 KiB
    Screenshot
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
Hmm. You could try fiddling with the xms=.... and ems=... settings.
And try different core=.... settings.
If that doesn't help, it becomes more difficult. There is a free replacement for DOS/4GW floating around calld DOS32A. It might work better. But before trying that, maybe it is easier to try one of daily CVS-builds of DOSBox. It is possible that it is cause by a bug in DOSBox 0.72, a bug that might be fixed in the next release.
_________________
Reply 2 of 11, by eL_PuSHeR
Rank Moderator
Moderator
I have played it using either VDMSound or DOSBox (old version, not current one). If I recall correctly you have to disable EMS usage inside the game's configuration.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Will there ever be a new version of Dosbox?
is the pope catholic?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 11, by MiniMax
Rank Moderator
Moderator
Does he wear a funny hat?
kicker04 - any luck with the suggestions I made?
_________________
Reply 7 of 11, by Reckless
I can run this game using DOSBox 0.72 without issue (I have my CPU cycles at 10000 for some reason or other and didn't check if it work with auto).
From the screenshot you provided, it could be when the game tries to play a digital sound (the newspaperman says 'extra, extra....'). Check your digital sound effects playback [with another game?].
Reply 8 of 11, by kicker04
No sorry, I didn't try that. That sounds a bit too complicated for me. I don't even know what is meant with ems and xms and core settings and so on. I just want to run the game.
Reply 10 of 11, by MiniMax
Rank Moderator
Moderator
Or you could try installing one of the many DOSBox frontends that makes it easier to change all those pesky DOSBox settings.
_________________
Reply 11 of 11, by Great Hierophant
This game should run with the default DOSBox settings and has for a long time, so I would suggest three possibilities:
The sound card is incorrectly setup
The OP's copy is damaged, or
The OP fiddled with something in an attempt to make it run.
