Wolfenstien 3d
First post, by silverwolf
So, I have the files for Wolfenstien 3D (The installer) And I'm trying to install, But the installer says, When I try to install "This Directory does not exist, would you like to create?" I'm trying to install it to c:\WOLF3D Which I created in vista beforehand, But it still says doesnt exist. Where is it installing it to? the installer is located in c:\users\"ownername"\documents\DOS\wolf3d\. What do I do? I dont want to mess Window sup, So help would be thanke d:D
Reply 1 of 1, by Gameart
Hi, so what folders did you mount on DOSBox exactly?
Anyway here is what I think you should do :
1) First it would be better to create a folder where you plan to install all your DOS games like C:\DOS for example
2) Launch DOSBox and mount the folder where the installer is located as D drive like so : mount D C:\users\"ownername"\documents\DOS\wolf3d
3) Then mount the folder that will act as the hard drive where you install the game as C drive like so : mount C C:\DOS
4) go to the D drive, launch the installer, install the game on C drive in C:\WOLF3D and answer yes when it asks you if you want to create the folder. The game will actually be installed in C:\DOS\WOLF3D but the thing is that for DOSBox the root of the C drive is actually C:\DOS ( instead of C:\ ) since you mounted that folder to act as a hard drive.
I hope that helps you.
