Colors mess up in DOSBOX
First post, by vsg1980
Right now I've played Quarantine and Shadow Warrior. After playing for a while (it happens randomly) the colors will mess up. The game is playable and I can control them just fine. It's just hard to see things because the colors go like, negative??? It's hard to explain, but it looks teal and cyan and purple in the places where the colors are supposed to make the object in the game world look like it has depth. You know how like gray would fade to black on a stop sign pole or something.
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
close all program that don't need to be running
it is some background application (usually something in the taskbar) that causes this.
Water flows down the stream
Reply 2 of 2, by vsg1980
You know what, thank you. I think I know exactly what's running back there that's causing it. Thanks again!
