Help DOS PROBLEM!!
First post, by 1130211
Im having a bug with dosbox and i need help
Im running on Vista and im having a problem thats only recently occured.
When i press the dosbox application an error pops up although it isnt stated
theres not Square or Info box that pops up that says "Error 4034"
its more like when i click it at the top of my computer screen tons of pixel squares pop up and cover 1/5 of the screen there little small boxes that vary
in colors of green black and blue. I need help if theres anyway to fix this because its making me mad. Yes i uninstalled dos and reinstalled it.
Yes i put it in administrative and compatabillity mode for XP.
><> <------ Fishy 😀
Reply 1 of 4, by ADDiCT
Whatever it is you're taking, cut down on it.
And then try to explain your problem in a way other people can understand.
Reply 2 of 4, by 1130211
I would if i could theres no other way to explain it unless i post a screen shot.
Theres no error box, no sound, Its just Random colors that radiate off of the DosBox Screen almost like the picture is fucked up.
><> <------ Fishy 😀
Reply 3 of 4, by eL_PuSHeR
Sounds like a video driver issue to me. Do you have all your drivers up to date?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 4, by 1130211
Yes thats what it was thanks
i just got a new NIVIDA graphics card and i guess it wasnt up to date..
Wow so i guess SOME PEOPLE ACTUALLY CAN UNDERSTAND MY PROBLEM..
Thank you for your help
><> <------ Fishy 😀
