keymap support?
First post, by robotriot
i've got some trouble with dosbox regarding the german windows keymap. i can't type \ for example, the key seems to have the american mapping assigned to it. this way, i have to switch to the us keymap every time before starting dosbox, which is quite annoying. is it possible to fix this issue?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
use / instead of \
and don't use a german keyboard layout 😉
To be honest some keyremapping system is planned, but we still aren't sure on how to do it. (and we haven't started it yet)
(we need a virtual keyboard drawn on the screen on which you can press a key with your mouse and press the key you want on it on the keyboard or so (and start with a fully layout american keyboard offcourse).. Add posiblity to save the mapping. to load it ... blah blah blah
map joystick to keys (maybe the reverse) etc etc etc
Water flows down the stream
Reply 2 of 3, by icemann
I`ve noticed lately that dosbox seems to be confusing my shift and 1 keys. Whenever in "dos prompt" in dosbox if I push shift a 1 will popup + if I`m attempting to define keys (eg Wolfenstein) which can be very annoying at times.
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Try a different version of sdl.dll
