Qbix wrote:well our pc speaker emulation keeps it's last value active. (so that the low part). Then it detects that it hasn't changed in a "long" time and turns itself off. (which results in a jump to zero).
The correct image would be even a bit different.
It would be a slowly converging line towards zero. so when it turn off there is no click.
That would work if the converging line doesn't end up making a "humming" artifact. SpeakerCorrect2.png shows what I believe you're talking about.
Another way to fix the popping would be to do what the Tandy 3-voice emulation seems to do--place the zero point in the center of the waveform. This would eliminate the click, as well as the need for a converging line. SpeakerCorrect3.png shows what this would look like.
Edit:
So you're sort of saying that the speaker emulation code places the silence at either the top or bottom of the waveform, depending on when the silence occurs? I'm asking this because I have never seen the silence happen at the top of the waveform. Is it even possible to perform any of my suggestions without a complete overhaul of the code?
Edit again: Just saw wd's post. I'll let this rest.
