Amulets and Armor, sound issues.
First post, by Burnov
I'm having trouble getting Amulets and Armor to recognize sound card emulation.
When I run setsound and it autodetects the gravis sound card, it technically works when I test it.
However when I run AA, it crashes right after the initial clap of thunder and the title screen.
Has anyone else had this problem?
Reply 1 of 23, by leileilol
Simple: don't use gus.
Reply 2 of 23, by Burnov
Okay, cool.
The game is running now, but it seems that when I use sound blaster for sound emulation there's sound when I test it, but not during the game...
At least the game runs now.
Reply 3 of 23, by wd
Rank DOSBox Author
DOSBox Author
Lei, feel free to make a list (or continue one of the postings on the beta
board) about games that don't work with gus 😀
Reply 4 of 23, by eL_PuSHeR
[MOVED]. Assuming you are using DOSBox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 23, by Xelasarg
Well, here's my fifty cents 🙄
Set GUS=false in your DOSBox conf.
"What's a paladin?!"
Reply 6 of 23, by cubancigar11
Hi!
This is an old thread, but I am having the same issue. There is no sound when I play this game. (I have tried Sound Blaster and Sound Blaster Pro.) Neither in the game nor in the setup.
Any idea?
Reply 7 of 23, by robertmo
have you set
gus=false
in your DOSBox configuration?
Reply 8 of 23, by cubancigar11
gus=false is already set...
Reply 9 of 23, by wd
Rank DOSBox Author
DOSBox Author
Then post at least SOME relevant information, otherwise it's just guessing.
Reply 10 of 23, by robertmo
try fixed cycles
Reply 11 of 23, by cubancigar11
Ok, I found the problem.
Thanks for your help you guys.
I should have mentioned before that I was using DOSBox from PortableApps.com
When launching DOSBox using their launcher (DOSBoxPortable.exe), there is no sound. But when it is launched directly, everything is flawless. (In both cases, Soundblaster is detected.)
Thanks again and very sorry for wasting your time 🙁
I will report a bug to PortableApps...
Reply 12 of 23, by wd
Rank DOSBox Author
DOSBox Author
If they are using ANYTHING different than the official release and a default
dosbox config file, they shall post here why they are doing that.
Reply 13 of 23, by robertmo
WD how about making a separate download with dosboxportable on dosbox.com so that people don't have to get it from freaky sites (with freaky config), as it gains popularity since dosbox 0.73 appeared.
Reply 14 of 23, by wd
Rank DOSBox Author
DOSBox Author
I don't see the need for a dosboxportable because dosbox is already fully
portable in that you can just copy the dosbox.exe+config file around as you wish.
Reply 15 of 23, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's the third time this comes up. Maybe you (Dosbox devs) should contact them and ask them what is up. As far as I understood from the other threads they are at least NOT using the default config because of how they manage the path to the portable device. Most likely their DOSBox binary is not the official version as well.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 16 of 23, by wd
Rank DOSBox Author
DOSBox Author
Well they're free to do what they like 😀 They just have to provide support for
it on their own if they do and people come here with issues.
Reply 17 of 23, by robertmo
That is not enough. You also have to add mount c .\folder in dosbox.conf and create a folder in dosbox folder. Also dosbox.conf is in hidden folder.
Reply 18 of 23, by wd
Rank DOSBox Author
DOSBox Author
Yeah that sounds like a lot of work.
That's why you can create your own easily.
But admittedly an independent unrelated release of exactly the same thing
plus the above things surely makes it unbelievably easier.
Reply 19 of 23, by leileilol
You don't even need to use gus=false. As far as I know, you'd only have to do that for Quake.
Amulets & Armor uses the HMI Sound System libraries and you can reconfigure the sound device easily by SETSOUND.
Running SETSOUND and choosing Sound Blaster 16 or Pro will solve this problem (one of these has compatibility problems with the game strangely)
PortableApps(dawt com!!) is a self-promotional joke.
