First post, by nickf80
Hi Everyone. I recently bought copies of Terminator Future Shock and Skynet. While I am able to play both games fine- I can't actually get far in the games because whenever I enter a door the game crashes. The error I get reads:
LIBRARY, Error : c:\tfs_swap.* 0.
My system specs/config if they matter is Vista 32 w/ 2GHz Core 2 duo w/ 3Gb ram. I'm currently using DosBox 0.72 with the Turbo Dos Box front end.
Note: I know that the 3d engines used for these games are the same as those used in Elder Scrolls: Daggerfall/ Battlespire (and these two games use the same door-room loading mechanic).
Please Help!
