QEMU 0.10.1 Released
First post, by DosFreak
http://www.nongnu.org/qemu/
Changelog
http://www.nongnu.org/qemu/changelog.html
version 0.10.1: […]
version 0.10.1:
- virtio-net: allow masking of notifications on empty queue (Alex Williamson)
- e1000: fix rx descriptor low threshold logic (Alex Willaimson)
- x86 tcg: add NULL checks to lsl instruction (Jan Kiszka)
- kvm vga: fix screen corruption with -std-vga and Windows (Avi Kivity)
- kvm vga: fix screen corruption with Ubuntu installations (Glauber Costa)
- virtio-net: check right return size on sg list (Alex Williamson)
- Make qemu_announce_self handle holes (live migration after hotplug)
(Marcelo Tosatti)
- Revert r6804-r6808 (qcow2 allocation info). This series of changes added
a high cost to startup for large qcow2 images (Anthony Liguori)
- qemu-img: fix help message (Aurelien Jarno)
- Fix build for non-default installs of SDL (Anthony Liguori)
- Fix race condition in env->interrupt_request. When using TCG and a dynticks
host timer, this condition could cause TCG to get stuck in an infinite
loop (Aurelien Jarno)
- Fix reading encrypted hard disk passwords during early startup (Jan Kiszka)
- Fix encrypted disk reporting in 'info block' (Jan Kiszka)
- Fix console size with tiny displays (MusicPal) (Jan Kiszka)
- Improve error handling in bdrv_open2 (Jan Kiszka)
- Avoid leaking data in mux'ed character devices (Jan Kiszka)
- Fix initial character device reset (no banner in monitor) (Jan Kiszka)
- Fix cpuid KVM crash on i386 host (Lubomir Rintel)
- Fix SLES10sp2 installation by adding ISTAT1 register to LSI SCSI emulation
(Ryan Harper)
version 0.10.0:
- TCG support (No longer requires GCC 3.x)
- Kernel Virtual Machine acceleration support
- BSD userspace emulation
- Bluetooth emulation and host passthrough support
- GDB XML register description support
- Intel e1000 emulation
- HPET emulation
- VirtIO paravirtual device support
- Marvell 88w8618 / MusicPal emulation
- Nokia N-series tablet emulation / OMAP2 processor emulation
- PCI hotplug support
- Live migration and new save/restore formats
- Curses display support
- qemu-nbd utility to mount supported block formats
- Altivec support in PPC emulation and new firmware (OpenBIOS)
- Multiple VNC clients are now supported
- TLS encryption is now supported in VNC
- MIPS Magnum R4000 machine (Hervé Poussineau)
- Braille support (Samuel Thibault)
- Freecom MusicPal system emulation (Jan Kiszka)
- OMAP242x and Nokia N800, N810 machines (Andrzej Zaborowski)
- EsounD audio driver (Frederick Reeve)
- Gravis Ultrasound GF1 sound card (Tibor "TS" Schütz)
- Many, many, bug fixes and new features
Make your games work offline
Reply 1 of 6, by ih8registrations
For all its features, it still falls over on most DOS games I try.
Reply 3 of 6, by ih8registrations
That's been around for a very long time in the source.
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
Feel free to try it, but before that have a look at the actual sources so you're
sure you know what exactly you're testing.....
Reply 5 of 6, by ih8registrations
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
