First post, by DosFreak
http://ve3d.ign.com/articles/news/45679/John- … ein-iPhone-Port
I had been frustrated for over a year with the fact that we didn't have any iPhone development projects going internally at Id. […]
I had been frustrated for over a year with the fact that we didn't have any iPhone development projects going internally at Id. I love my iPhone, and I think the App Store is an extremely important model for the software business. Unfortunately, things have conspired against us being out early on the platform.
Robert Duffy and I spent a week early on starting to bring up the Orcs & Elves DS codebase on the iPhone, which would have been a nice project for a launch title, but it wasn't going to be a slam dunk. The iPhone graphics hardware is a more capable superset of the DS hardware (the driver overhead is far, far worse, though), but the codebase was fairly DS specific, with lots of Nintendo API calls all over the place. I got the basics drawing by converting things to OpenGL ES, but I was still on the fence as to whether the best approach to get all the picky little special effects working would be a complete GL conversion, or a DS graphics library emulation layer. Coupled with the fact that the entire user interface would need to be re-thought and re-tested, it was clear that the project would take several months of development time, and need artists and designers as well as coding work. I made the pitch that this would still be a good plan, but the idMobile team was already committed to the Wolfenstein RPG project for conventional Java and BREW mobile phones, and Anna didn't want to slip a scheduled milestone on the established, successful development directions there for a speculative iPhone project.
After thinking about the platform's capabilities a bit more, I had a plan for an aggressive, iPhone specific project that we actually started putting some internal resources on, but the programmer tasked with it didn't work out and was let go. In an odd coincidence, an outside development team came to us with a proposal for a similar project on the Wii, and we decided to have them work on the iPhone project with us instead. We should be announcing this project soon, and it is cool. It is also late, but that's software development...
Late last year, the mobile team had finished up all the planned versions of Wolfenstein RPG, but EA had suggested that in addition to the hundreds of customized versions they normally produce for all the various mobile phones, they were interested in having another team do a significant media quality improvement on it for the iPhone. While Wolf RPG is a very finely crafted product for traditional cell phones, it wasn't designed for the iPhone's interface or capabilities, so it wouldn't be an ideal project, but it should still be worth doing. When we got the first build to test, I was pleased with how the high res artwork looked, but I was appalled at how slow it ran. It felt like one of the mid range java versions, not better than the high end BREW as I expected. I started to get a sinking feeling. I searched around in the level for a view that would confirm my suspicion, and when I found a clear enough view of some angled geometry I saw the tell-tale mid-polygon affine swim in the texture as I rotated. They were using the software rasterizer on the iPhone. I patted myself on the back a bit for the fact that the combination of my updated mobile renderer, the intelligent level design / restricted movement, and the hi-res artwork made the software renderer almost visually indistinguishable from a hardware renderer, but I was very unhappy about the implementation.
I told EA that we were NOT going to ship that as the first Id Software product on the iPhone. Using the iPhone's hardware 3D acceleration was a requirement, and it should be easy -- when I did the second generation mobile renderer (written originally in java) it was layered on top of a class I named TinyGL that did the transform / clip / rasterize operations fairly close to OpenGL semantics, but in fixed point and with both horizontal and vertical rasterization options for perspective correction. The developers came back and said it would take two months and exceed their budget.
Rather than having a big confrontation over the issue, I told them to just send the project to me and I would do it myself. Cass Everitt had been doing some personal work on the iPhone, so he helped me get everything set up for local iPhone development here, which is a lot more tortuous than you would expect from an Apple product. As usual, my off the cuff estimate of "Two days!" was optimistic, but I did get it done in four, and the game is definitely more pleasant at 8x the frame rate. And I had fun doing it.
Since we now were doing something resembling "real work" on the iPhone at the office, we kept it going at a low priority. One of the projects Cass was tinkering around with at home was a port of Quake 3, and we talked about different interface strategies every now and then.
Unfortunately, when we sat down to try a few things out, we found that Q3 wasn't really running fast enough to make good judgments on iPhone control systems. The hardware should be capable enough, but it will take some architectural changes to the rendering code to get the most out of it.
I was just starting to set up a framework to significantly revise Q3 when I considered the possibility of just going to an earlier codebase to experiment with initially. If we wanted to factor performance out of the equation, we could go all the way back to Wolfenstein 3D, the grandfather of FPS games. It had the basic run and gun play that has been built on for fifteen years, but it originally ran on 286 computers, so it should be pretty trivial to hold a good framerate on the iPhone.
The above quote isn't all not by a long shot..
Make your games work offline
Reply 1 of 3, by DosFreak
IPHONE Wolf3D Source
The FTP site (yeah....FTP....) is overloaded of course.
Alternate
http://www.atomicgamer.com/file.php?id=76769
I wonder if he checked out Wolf4SDL?
http://www.stud.uni-karlsruhe.de/~uvaue/chaos/
Reply 2 of 3, by temptingthelure
Email him and ask him if he has. 😀
