First post, by DosFreak
http://www.emuhq.com/emulators/computer/macin … 2009/04/01/9168
http://www.emaculation.com/forum/viewtopic.php?t=5325
Fixes (taken from CVS change messages, but not a far back as the original windows build): -Cursor placement. -Mouse lock-up afte […]
-Cursor placement.
-Mouse lock-up after frequent movement in and out the SheepShaver window
-Multi-mouse button support through e.g., TheMouse2B
-CD-rom support improved
-Fix file corruption experienced when doing random-access
file I/O to the external filesystem
-Cope with assembler updates in emulated CPU
-Support for 64 bit Intel/ia64
-FPU instructions added
-SSE and MMX optimizations
-SSSE3 optimizations (Intel Core 2 CPUs and newer)
-Update to slirp sources from QEMU 0.9.0
Problems (Solved by newer build linked above?):
-sometimes restart error for OS 9, not OS 8.6 To solve this issue, use the SDL.dll version 1.2.10, included in the download
-networking is still unstable using slirp
Doesn't work in 2008 64bit. 🙁
Make your games work offline
