First post, by colinator
Hi all, Ive read another post about this but there doesnt seem to be a solution so here im trying again to get an answer 😖
What is the problem??
I use Wolfenstein 3D 1.4 (registerd)
i downloaded the free super addon upgrade from 3Drealms and installed it
when i launch Wolfenstein 3D, it works perfect, but when i use Wolfm.exe (the upgrade!) to create new levels, it also goes well, but when i launch Wolfenstein 3D from Wolfm or just from Command Prompt it hangs on the memory check screen with, One Moment, and then DOSbox crashes,
I use Dosbox 0.72
Reply 1 of 2, by bugzy1977
it happens in the new 0.73 too
i'm still waiting for an answer.
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
Locked. Thread continues here:
Wolfenstein 3D Super Upgrades addon pack + dosbox all versions
_________________
