First post, by wolf
I am trying to run the Monkey Island CD-ROM version, and I can easily mount the BIN/CUE file, launch the games launcher, but then it says it can't find the CD, even though the game runs off the CD.
So I was recomended to use:
-usecd 0 -ioctl
and can't get it to work. Here is what I used:
imgmount d d:\emulation\microsoft\dos\games\d\monkeycd\monkeycd.cue -t iso -usecd 0 -ioctl
I know the game works and all the audio files are there.
Reply 1 of 12, by MikeRS
-usecd and -ioctl are for the plain "mount" command not the imgmount command, so if you put your real CD into the real CD drive, that's where they apply.
Reply 2 of 12, by wolf
Any suggestions then on how I would get this game working using -t iso?
The game uses CD Audio files that won't transfer if I extract the files manually and put them in a folder. The 500+ mb disc image then becomes like 50 mb in a folder. The game will work perfectly then, but I loose the voice and music in game.
Reply 3 of 12, by wd
Rank DOSBox Author
DOSBox Author
Please post the exact mounting (preferrably dosbox.conf) and a screenshot of the error message.
Reply 4 of 12, by Reckless
Does it work wth your CD instead of the image?
Reply 5 of 12, by wolf
Trying this from actually CD and mounting the CD-ROM drive does the same thing. Tells me to insert CD. Even though the game launches from the CD. It is not istalled into the drive.
I know the game works because dumbing the files into a folder works, just no sound or voices since the audio files don't transfer as posted before.
My CONFIG file
[collapse]
# This is the configurationfile for DOSBox 0.72.
# Lines starting with a # are commentlines.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest,pause (when not focussed).
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=true
fulldouble=true
fullresolution=1280x960
windowresolution=1280x960
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
priority=pause
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory DOSBox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=128
[vga]
videoram=2048
svgachipset=3s
[render]
# frameskip -- How many frames DOSBox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,hq2x,hq3x,
# 2xsai,super2xsai,supereagle,advinterp2x,advinterp3x,
# tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
# If forced is appended (like scaler=hq2x forced), the scaler will be used
# even if the result might not be desired.
frameskip=0
aspect=true
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
# auto switches from normal to dynamic if appropriate.
# cycles -- Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# You can also let DOSBox guess the correct value by setting it to max.
# The default setting (auto) switches to max if appropriate.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=intelligent
device=default
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=48000
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation. Covox Voice Master and Speech Thing compatible.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
# joysticktype -- Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks,
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# timed -- enable timed intervals for axis. (false is old style behaviour).
# autofire -- continuously fires as long as you keep the button pressed.
# swap34 -- swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap -- enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=false
autofire=false
swap34=false
buttonwrap=true
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq.
# for directserial: realport (required), rxdelay (optional).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support.
# keyboardlayout -- Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
mount c D:\Emulation\Microsoft\DOS\Games\C\ -freesize 1500
c:
[/collapse]
my commands I use:
[collapse]
d:
monkey.exe
[/collapse]
Reply 6 of 12, by wd
Rank DOSBox Author
DOSBox Author
Please use the official 0.72 release for bug reports, NOTHING else.
Reply 7 of 12, by wolf
offical release? This is the latest version right out of the main site. 0.72.
Reply 8 of 12, by MiniMax
Rank Moderator
Moderator
Maybe... But where did the config file come from?
Looking at my copy of the dosbox.conf file that came with 0.72 I see these differences:
You have:
memsize=128
I have:
memsize=16
Btw, DOSBox will never make more than 63 MB available so those 128 is meaningless. If you are lucky, you will get 63 MB. If you are unlucky, DOSBox will only look at the first 2 digits and give you 12 MB.
And this section is totally missing from my copy:
[vga]
videoram=2048
svgachipset=3s
_________________
Reply 9 of 12, by wolf
I see. I better change it to 64 then if it only reads the first 2 numbers 😳
So, see anything else wrong? I didn't change too much. If I changed something that might cause conflicts or problems, I will change it.
The [VGA] section I got from the DOSBox Wiki somewhere. Might have been from an older version, they kept referring to 0.6 something. I will take it out... I doubt it does anything.
Reply 10 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
make a whole new conf (load dosbox without a dosbox.conf and do a "config -writeconf dosbox.conf" and adapt this one for the settings you know you need. Do this every time you change versions.
Side note, I'm glad that 0.73 will do this a whole lot better.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 11 of 12, by wolf
I figured it out! I had memsize set to 64 instead of 16. I tried 64 a long time ago and did not notice it was still there. This also fixed a problem I had installing "Lost in Time".
Thanks for all your help everyone.
Bye the way, I looked at memsize thanks to Qbix mentioning something about most games not working when memory is past 16!
Thanks Qbix!
Reply 12 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
maybe you understand now. why we said that you should use clean configfile...... We knew the solution right from the start... (at least for the lost in time problem)
Water flows down the stream
