First post, by danielc
- Member
I searched for this to see if anyone else reported it, but it's one of those things that isn't easily explained.... dunno if it's just my hardware configuration or if others are having it....
What happens is, say i'm just at the command prompt in DOSBox, if I ALT+TAB (or simply switch to another window) in Windows, do some stuff, then switch back to DOSBox, a wierd thing happens 90% of the time... it's as if the TAB key is being held down.... as fast as the keyboard repeat/delay allows, the autocomplete filenames in the current folder rapidly change (and loop). As if you're holding TAB... even though you're not. You have to press TAB, or UP/DOWN arrow, or ESC... followed by ENTER or BACKSPACE to get rid of the autocomplete filename it was left on when you interrupted it....
....does that make sense? Has anybody else witnessed this? Only bug i've managed to come across lately. O.S. is Windows 7 Build 7057 64-bit (but it also happened in Vista SP1 32-bit from memory).
Regards,
CosmicDan
