First post, by Force_Phenomenon
Hello, this is my first time posting and I did attempt to dig through the forum index to find a solution to my problem, but came up with nothing, so please be gentle if I overlooked anything. Here goes.
Back in '07 I picked up DOSBox 0.65 after being hit with a heaping helping of Nostalgia for old dos classics. It suited me perfectly and everything ran fine, even the mouse, which I know for a fact since I played the Riddle of Master Lu and this glitch did not plague me.
Time went on. I noticed Dosbox 0.72 had been released, downloaded it since it boasted bigger compatibility, again, no problems.
After said nostalgia above had been satisfied I took a break for nearly an entire year before picking it up again. I noticed a strange bug. I'd click in the dosbox window to capture my mouse, but when I'd move it.. the game would freezeframe, as would dosbox itself. I first noticed when playing Blake Stone Planetstrike. I figured it was just that game. But when I went to play the Riddle of Master Lu again, the same problem occured, to the point if I moved my mouse too much it would crash the game or dosbox itself. I know it's a problem in my PC, because I switched back to Dosbox 0.65 and the same problem occured. Other than driver upgrades and software upgrades, I cannot think of anything that would cause this. When I play, I have no other active programs running. Here is a list of my hardware specs:
Intel Core2 Duo @ 2Ghz
4GB Ram (only 3 read due to XP)
Twin eVGA GeForce 7950 GT's (Not in SLI and yes I know, old, upgrading soon.)
Creative X-Fi Elite Pro
Windows XP Professional SP3
500 GB and 320 GB internal SATA2 Western Digitals, 200GB and 120GB external USB Segates, and 120GB SATA1 through ESata Segate.
The folder with all the games in it I use to mount is located on the 320GB internal drive.
This might be an information overload for most but I figure, too much rather than too little. If I need to post anything else, ask and you shall recieve. I'm hoping someone can provide an answer for this.
Edit: Forgot to add. Keyboard is Logitech G15 Gaming keyboard (original blue) and Logitech G7 mouse.
[/img]
