First post, by StannyMann
I am trying to run Magic Carpet Plus from an iso image file on my HDD using a fresh install of Dosbox 0.72.
I mount C:\dosbox to C and the image file to D with imgmount:
mount c c:\dosbox
imgmount d d:\dosbox\***.iso -t iso
I can switch to drive D: and dir lists the executable 'carpet.exe' so I know the image mounted correctly. However, when I type in carpet, I get the Dos4GW initial text and some files are copied to C:\ but then the game hangs at a black screen with no video output.
Oh and this iso image loads fine on Virtual PC and runs with sound okay, but it is real choppy so I thought I'd give Dosbox a shot.
I have read the readme and various posts on MC and mounting image files.
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
Works for me. Here is my config:
# Title:        Magic Carpet Plus
# Developer: Bullfrog Productions, Ltd.
# Publisher: Electronic Arts, Ltd.
# Year: 1995
# Genre: Action
# Status: Commercial
# Link: http://www.mobygames.com/game/magic-carpet-plus
# Link: http://en.wikipedia.org/wiki/Magic_Carpet_(video_game)
# MD5-sum: 8669ca5481c3a7ebf4c02b822c1d4ca7 *D:\Carpet.Exe
# MD5-sum: 0763e103ed4935276050a0690f464850 *D:\Carpet\Carpet.Exe
# Archives:
# Run: D:\Carpet.Exe
# Setup: D:\Carpet.Exe
# Save-games: C:\Carpet.CD\Save\*.*
# Game-configs: C:\Carpet.CD\CP.Dat C:\Carpet.CD\Language.Inf C:\Carpet.CD\SndSetup.*
# DOSBox: 0.72
# By MiniMax
[sdl]
output=overlay
windowresolution=1024x768
[render]
aspect=true
[autoexec]
@ echo off
rem +---------------------------------------------------------------
rem ! Mount the virtual diskette drive and virtual harddisk.
mount C "C-drive"
rem mount D "D:\" -t cdrom
imgmount D "G:\Spool\ISOs\CARPET.iso" -t cdrom
echo.
rem ! Switch to the CD-ROM, and inform the user about which
rem ! command to use for running the game.
D:
cd \
echo Type CARPET to start the game.
goto Done
:Done
echo.
Maybe compare your checksums with mine and see if it really is the same game?
_________________
Reply 2 of 2, by StannyMann
Got it. I had to extract the iso to a directory on my HD and then mount as cdrom
mount d c:\dosbox\carpet -t cdrom
plays fine now.
Kept hanging when I tried to mount the iso directly as -t iso or -t cdrom.
Thanks for your help
