I dont know if it matters that much, but that causeway linker & extender doesn't cause dosbox to leak...... Let me try MSC 5
edit MSC 5.1 doesn't explode out.... didn't the old borland 3.x stuff run in protected mode...? I vaugely recall something like that...
I wonder if it's programs that open & close files like wild in PM cause the issue.....
I'll have to test something further.
What is interesting is that eventually, depending on the OS, it'll over commit, and then the memory usage will drop down to 5-9MB!!!!!
I wonder if it's easy to outright remove all the file/directory cache?
