First post, by Sheriff Hobbes
Hi guys,
I'm new to DOSBox, but not new to DOS, I have started my "gaming career" with DOS games and I have lots of them. I still have a running native DOS computer, but I started testing all my games with DOSBox, mainly for convenience purposes and because my old PC may die one day. I will list all the games I couldn't get to run here. This will a) improve the BOSBox game database and b) hopefully help me getting more games to run. 😀
This is the first problem description. I will always follow the guidlines for help requests.
1.Motherboard: a) Asus P5LD2 SE
b) Asus A8V-VM
2.Processor type and speed: a) Intel Core 2 6600 (2 x 2.66 GHz)
b) AMD Athlon 64 X2 Dual Core 4200+ (2 x 2.2 GHz)
3.Amount and type of RAM: a) 2 GB DDR2
b) 4 GB DDR
4.Video board w/ RAM amount and type: a) Asus GeForce 7900 GTX, 512 MB
b) Xpert Vision GeForce 7100 GS, 128 MB
5.Sound board: a) Creative Soundblaster X-Fi XtremeGamer
b) Creative Soundblaster Audigy
6.Operating system: a) Windows XP
b) Windows Server 2008
7.Game name (and version, if applicable): Armored Fist 2
8.Description of problem: During loading of any level, DOSBox crashes with the following error info:
AppName: dosbox.exe AppVer: 0.72.0.0 ModName: dosbox.exe
ModVer: 0.72.0.0 Offset: 00095800
9.Reproducibility of problem (always, only once, always but only on a specific level, etc.): always
10.Sound mode used: SB16
11.Video mode (Software, OpenGL, Direct3D, or Glide, and resolution): opengl, surface
12.Version of emulator: DOSBox 0.72 with Frontend D-Fend 0.6.1
13.Steps already attempted to solve the problem (please say you've read the README if you haven't, and READ IT IF YOU HAVEN'T!): Yes I've read the whole readme. So far I've tried the following:
- Tested all combinations of memory settings (amounts of MB, Loadfix, XMS, EMS, UMB)
- Tested all other supported DOSBox versions (0.70, 0.71)
- Game works perfectly with same install media on real DOS
As you can see I always test with two totally different platforms [a) and b)].
Thanks,
Sheriff Hobbes
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 1 of 11, by eL_PuSHeR
Congratulations, at least you posted a comprehensive report. 😎
BUT, according to Mobygames, Armored Fist 2 is A WINDOWS GAME.
DOSBox is meant for MS-DOS games.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 11, by Sheriff Hobbes
I wouldn't have been able to install and start it in DOS if it was a Windows game. 😉
Mobygames is wrong.
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 3 of 11, by peterferrie
Yes, Mobygames is wrong. A Windows installer delivers a 32-bit DOS program.
Sheriff Hobbes, does the demo version play on your system?
That one works for me, but maybe the real game is different somehow.
Reply 4 of 11, by Sheriff Hobbes
I don't have the demo version. The crash surprises me because Comanche 3 has the same engine as AF2 and it runs fine!
Is jyri00555 in this forum?
He made an entry at dosbox.com (http://www.dosbox.com/comp_list.php?showID=2988&letter=A) but what he says doesn't make sense.
He says 100% supported, but then as a note:
"Everything is fine,until the setup part. IT can't detect CD-ROM speed. Without setup ran first, the game won't run."
I guess he postet this note for version 0.63 and could get it running with 0.72. I would like to know which settings he made for DOSBox.
Just another note if anybody else would like to run the game: you need to stick to the default drive letters, which is C: for the game and D: for CD-ROM. Otherwise you will get an "insufficient memory" error! Same for Comanche 3!
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 6 of 11, by Sheriff Hobbes
I found the reason for the problem, but no solution yet.
The game won't run from an ISO file. With the real CD it runs fine. I created the ISO several times, even with different tools.
Maybe the ISO access is too quick, so the game might skip files during level load? Is there a way to slow it down?
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 7 of 11, by Sheriff Hobbes
I found a fix!! 😀 😀
I copied the CD data to hard drive and mounted the folder as D:\, which was my CD-ROM drive letter. Works!
However, the game is pretty slow, so I will play it under real DOS as long as possible. 😉
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 9 of 11, by rcblanke
Just some additional stuff I found out:
* Game does indeed crash when running with an ISO or BIN/CUE (imgmount d game.iso -t iso) with either 'small' or 'normal' installation type
* Game runs fine when running from a real mounted CD (mount d e:\ -t cdrom) with any installation type
* Using reduced cycles (for example 10000) makes the loading screen fail in another way, complaining about a missing .pcx file (I suppose those live inside the big .res files). The strange thing is that, at that point, all files on the emulated cd-drive (d:) have gone missing; dir on d: displays 0 files ?!?
* Game runs fine when running with an ISO or BIN/CUE with the 'large' installation type!
Reply 10 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
hmm nice one to debug then. can you make a topic about on the beta forum ? It is interesting as there are more games that sometimes can't find files on a cue/bin (Xcom apoc, but there it happens random and after long playing so not very easy to debug)
Water flows down the stream
Reply 11 of 11, by Sheriff Hobbes
Using reduced cycles (for example 10000)...
Are you crazy? AF2 has very high demand on CPU, it can use every cycle you got! 😀
-engagement ring
-wedding ring
-suffering
H. L. Mencken
