First post, by Magnus89
Hi, I’m having an issue with Doom in Dosbox. I can only access the game one time after I install it and set the settings and launch through that screen. After that, it will not allow me to launch again from the same install – I have to delete the folders contents, remount the drive, reinstall, reset the settings and then I can launch it after I do all of that (it refuses to work the same way when done directly through the mounted drive's setup file also). I know there's supposed to be a file in there somewhere which will automatically launch the game when typed into the dosbox, but I haven't been able to find which one it is, even with "dir" and typing each of the listed directories names - none work.
Also, I can’t figure out how to keep the virtual drive folder mounted (unless I am mistaken, you’re supposed to be able to keep it mounted right?). Other than those two little snags, everything works perfectly – including audio. It’s just really frustrating to have to do all of this to play this game each time, without being able to save and restart a saved game...
I am using http://www.dosgames.com version of the game under 3D Shooters section.
Thank you in advance, any help here is greatly appreciated!
