First post, by 40364
While using DosBox, I'm finding that in certain rudimentary games like ZZT, Kroz, Castle Adventure, and Caves of Thor, whenever I release one key, all keys are considered released in the game. This makes rounding corners difficult: hold left, hold up, release left = full stop. Just curious if there is an easy solution to the problem that I missed, or if it even happens on other computers. Using DosBox 0.72, WinXP
Reply 2 of 4, by 40364
Releasing a key doesn't stop the currently repeating key in XP NTVDM.
I should mention that the behavior is also present in the DosBox shell command prompt.
Is it safe to assume that this doesn't occur on most systems?
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Not sure I am testing the right thing....
I press J (J repeats), I keep pressing, I press K (K starts repeating), I release J, and:
in CMD-prompt: K still repeats
in COMMAND-prompt: K still repeats
in DOSBox: K stops repeating
_________________
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
might be a bug. I see that our keyboard key release simply clears the repeating key code.
Water flows down the stream
