First post, by ItsJustMe
Hi,
I started using Dosbox to get an old program working I used to run on my PII 400 under Windows with slowdown. Since the C2D is far to fast to use slowdown (err, have to start it 8 times...) i found dosbox. So....
This program can write prn files so dosprn can print em to my pdf printer. After using h-a-l 9000 megabuild 4.1 it writes the prn files - almost.
It writes only the first 4KB (and i mean exactly 4096 bytes). After quitung the program and getting back into the dosbox, the file is completed...
But:
The Programs can print 2 different things: measurement and tender (hope i choose the right words, it's german (like me 😉))
Printing a measurement works fine (up to 50kb I've seen) - but printing tender only works completely when quiting the program afterwards...
Some an idea?
Greets
Peter
Edit:
Found out that even the 50kb are only ~50% of the printjob. After quitung it gets 99kb. So it always writes about 50%...
