C drive write protected.
First post, by mclatilla
Hi all!
I'm from Spain (sorry for my english 😀)and I've been using DOSBox for a long time to play my old games. It's a program that I appreciate a lot and it always worked as intended.
I work in Madrid, at the AVE Maintenance Workshop. We maintain the High Speed Trains called AVE Class 100 from ALSTOM:
http://en.wikipedia.org/wiki/AVE_Class_100
You would be pleased to know that we use DOSBox in the workshop everyday!
We use it to communicate via serial port with the different systems:
-Main control unit
-Recorder unit (crash recording)
-Air conditioning systems: driving cars and passenger cars
-Etc...
These systems have custom 15-year old DOS programs that only work with slow processors, i.e. 486, Pentium without L1 cache, etc due to erratic behaviour of the serial port.
One day we tried DOSBox, configured the serial port to directserial, adjusted cycles to 300 and voila!! It solved almost all our communication problems 😀
However, one of the executables, the passenger cars air conditioning one doesn't work properly in DOSBox. It displays with a "C drive is write protected" message so it can't create a file to store the readings.
In a normal Windows XP command prompt, the program runs fine (except for the lack of communication!)
It's strange indeed because the driving car air conditioning program is very similar and works without a glitch!
I've been searching the forums for similar problems but I'm a bit dissoriented :s
I attach the EXE file (in spanish, sorry!) to try it for yourselves... Just press the Enter key inside DOSBox a couple of times to see the error message. Try it in a command prompt to see what it should do.
I've tried several DOSBox versions without luck. Tried also several options.
What should I try to get it working? Is the program trying to access the disk in a non-supported way?
Thanks a lot, indeed.
Reply 1 of 25, by MiniMax
Rank Moderator
Moderator
I tried it, and I get the same error message. I tried to mount the C-drive with a large -freesize 2000 but that didn't make any difference. Don't know what could be wrong here.
_________________
Reply 2 of 25, by mclatilla
Thanks for trying it 😀
Reply 3 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
it doesn't seem to use dos calls to determine the write protection.
Water flows down the stream
Reply 4 of 25, by wd
Rank DOSBox Author
DOSBox Author
It uses portlevel disk access. Will not be supported by dosbox.
Besides that, it should again be noted that dosbox is supposed to be used
with games only, every other usage may have arbitrary results and we
won't take ANY responsibility (train crashes? hm).
Reply 5 of 25, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Why does it work in NTVDM though?
1+1=10
Reply 6 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
it might just use some values to detect the write protection or so.
Or some different branch is taken in dosbox.
Similar application worked fine according to the OP.
Reply 7 of 25, by wd
Rank DOSBox Author
DOSBox Author
The ports stuff? Wouldn't know why there'd be a problem with it.
Reply 8 of 25, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
NT will certainly not let a DOS application touch the real hardware ports.
1+1=10
Reply 9 of 25, by wd
Rank DOSBox Author
DOSBox Author
afaik that's wrong, like floppy ports are fully accessible, part of the vga registers.
Guess the same for the ide stuff.
Of course they're virtualized so the vdm can modify/disallow combinations.
Reply 10 of 25, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If that was true a virus running in NTVDM could kill the system. They may be emulated to some extent but are not forwarded to real hardware.
Anyway, I've given the program the register read value it wants (IDE register write-read test): it will go further but later complain about write protection again, this time without accessing IDE ports.
1+1=10
Reply 11 of 25, by wd
Rank DOSBox Author
DOSBox Author
That's up to the vdm, iirc the floppy stuff was forwarded in most parts.
Hacking out the port checks makes the app work.
Reply 12 of 25, by peterferrie
The ports are not forwarded directly to hardware under Windows.
Windows decides which ones it will service on its own, and which it will queue for eventual passing to the hardware (because it can't pass it immediately in case another request is already active).
I'll have a look at this. It sounds like a fun puzzle.
Reply 13 of 25, by wd
Rank DOSBox Author
DOSBox Author
"queuing+passed to hardware" isn't THAT far from "virtualitzed+forwardedifneeded".
As noted above it's already solved, but feel free to have additional fun.
Reply 14 of 25, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
My computer has no floppy but still the program works in NTVDM.
Even after pressing Y ?
1+1=10
Reply 15 of 25, by mclatilla
wd wrote:
Besides that, it should again be noted that dosbox is supposed to be used with games only, every other usage may have arbitrary results and we won't take ANY responsibility (train crashes? hm).
Don't worry about that! 😀
I attach the similar program that works. I guess this one it uses regular DOS calls instead, doesn't it?
Reply 16 of 25, by peterferrie
There's a check for write-protection, whose result is checked in two different places in the code. The code that sets the state can be patched (just one byte), which makes the program run for a while. Then I see "unexpected error" (perhaps because it can't communicate with anything).
Use a hex editor to change the byte at offset 0xb82d from 03 to 00.
Reply 17 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
but what does it check ? (as it works on hals pc without a floppy drive)
Reply 18 of 25, by wd
Rank DOSBox Author
DOSBox Author
Yes. If it's the same that i remember.
Reply 19 of 25, by wd
Rank DOSBox Author
DOSBox Author
Suppose real hw, even if no drive is attached, return 0 instead of 0xff.
