First post, by seasoned_geek
Per previous closed thread about RPM in OpenSuSE distro
received this email just moments ago
http://bugzilla.novell.com/show_bug.cgi?id=502572
User sven.burmeister@gmx.net added comment
http://bugzilla.novell.com/show_bug.cgi?id=502572#c1
Sven Burmeister <sven.burmeister@gmx.net> changed:
           What    |Removed                     |Added
             Status|NEW                         |NEEDINFO
                 CC|                            |sven.burmeister@gmx.net
      Info Provider|                            |roland@logikalsolutions.com
--- Comment #1 from Sven Burmeister <sven.burmeister@gmx.net>  2009-05-15 09:55:07 MDT ---
Is dosbox a KDe app? If not the maintainer of that package should be assigned
to this report.
Configure bugmail: http://bugzilla.novell.com/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are the Infoprovider for the bug.
You reported the bug.
Reply 1 of 6, by Kippesoep
DOSBox isn't a KDE app. The maintainer of the package is probably yet another person, unless they use the RPM from the DOSBox download page, which I somehow doubt. I guess that adds a fourth party 😜
My site: Ramblings on mostly tech stuff.
Reply 2 of 6, by MiniMax
Rank Moderator
Moderator
What is the definition of "a KDe app"? Maybe mr. Burmeister know?
_________________
Reply 3 of 6, by leileilol
an application that loses features and gains glitz among its updates for the KDE shell on Linux.
long live PCem
Debian's fucked
Reply 4 of 6, by frobme
A KDE app would be one that works off the KDE base libraries and follows the common GUI control scheme of KDE, etc.
No, Dosbox isn't a KDE app, and has no need to be - it's SDL, it controls it's window completely, and since it doesn't pop up things like file dialog boxes, it doesn't need to use the KDE widget set. This conveniently keeps it out of the religious wars surrounding widget sets as well!
The bug listed is simply in the formation of the install package, and really has nothing to do with Dosbox. Some well intentioned person just gave it an entry on the KDE programs menu without filling in another required field (so Dosbox knows where it's running and has permissions to write out a conf file).
In short, this has nothing to do with Dosbox. Whoever submitted the package to the SUSE repository just needs to add one line to their install.
Oh, and this is just a rehash of stuff that has been thrashed to death but I missed the first time: config seems broken
-Frob
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
Thanks frobme - I didn't know the exact answer but I was pretty sure that DOSBox was not an KDE app, and hence the whole fingerpointing was being being directed the wrong way.
_________________
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
nonetheless the problem with the configuration file will probably be less of an issue with 0.73 as that one will create one by default if it can't find one.
Water flows down the stream
