First post, by Salient
I recently bought an SC-55 for very little money and I decided to try to do with it what I did to my MT-32.
Basically what I did is took an existing 'low profile' power supply of 12 Volts, added an 7809 voltage regulator and connected it internally to the 9V plug. Then I drilled and cut a hole in the casing to make room for the mains connector. Then I connected that to the power supply, glued the plastic holder for the power supply on top of the 3 chips of the sc-55 mainboard and voila, an sc-55 like an sc-88. 😀
Photo's (clickable for bigger versions):
Reply 1 of 15, by HunterZ
xs4all.nl is blocked at work, can't see the pics 🙁 Sounds cool though, someone should do the same with an MT-32 - there's a good amount of space inside of its case I think.
Reply 2 of 15, by Salient
Actually I have done this with my MT-32 as well long before. 😀
Indeed on the left side in the casing there is plenty of space.
Here is the pic (clickable):
Reply 3 of 15, by rushko
Will it affect the sound quality on the output?
Reply 4 of 15, by Salient
With the SC-55 I hear no difference at all with the internal or external psu.
With the MT-32 only when I set my amplifier at near maximum I hear a vague 50hz noise which I believe wasn't there with the external power supply. However in normal use I never notice it.
Reply 5 of 15, by keropi
that is a very nice idea, might do that to a CM-32L I have... 😀
nice job!
Reply 6 of 15, by Salient
nice job!
Was thinking about that myself also, but I doubt there is enough space in the CM32L.
Will open my MU80 soon too to find out if I can do the same with that thing also. 😀
Reply 7 of 15, by Salient
A little update on the power supply (thanks to mace):
Added 2 capacitors to smoothen the regulator's output.
Reply 8 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You really shouldn't put the output wires so close to the live ones.
1+1=10
Reply 9 of 15, by Salient
It's just a short distance and the device doesn't draw a lot of current. Why would it be bad to have them next to eachother?
Reply 10 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If the isolation fails you get electrocuted.
1+1=10
Reply 11 of 15, by Salient
I'm counting on the isolation not to fail 😀
Reply 12 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Well as long as you don't encorage others to do it that way...
1+1=10
Reply 13 of 15, by HunterZ
Shouldn't be a big risk if the enclosure is kept sealed since there are no moving parts inside :p I was thinking you were going to say it might cause EMI issues.
Reply 14 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The glue or isolation can melt (who says the power supply can't partially fail and produce a lot of heat?) and then you have moving parts. There are possibly sharp edges that cut in the isolation over time. Keeping the wires and voltage regulator away from the live side is only a small effort but decreases hazard a lot.
Oh, and from the EMI side: The live side of a switching power supply produces lots of interference, you'd like to put it as far away from analog audio stuff as possible.
1+1=10
Reply 15 of 15, by Salient
I hear no interference at all, even with my amp. wide open. at least not more than with the original external power supply.
But maybe you are right about the danger of melting. Although it's unlikely to happen I will take some actions to make sure the live wires will not be able to touch the output wires in case of overheating.
