First post, by MusicallyInspired
Why is this? I have Daggerfall's detail set to max and it runs fine. With Arena's detail set to max the game is really slow. It's an older game and should run more smoothly than Daggerfall, shouldn't it? I have the cycles set to "max" in the config file because it wouldn't do this automatically with Arena like it does for Daggerfall. It's still slower, though.
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
set core=dynamic as well for arena
Water flows down the stream
Reply 2 of 6, by MusicallyInspired
Ah, there we go. Thank you! Why doesn't DOSBox set these settings automaticall with 'auto' like it does with Daggerfall? Just because the game is older?
My Github
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
yes. the "auto" values can't detect everything
Reply 4 of 6, by red_avatar
Just wondering, but are there downsides to using dynamic? Because there aren't really many games that have issues with dynamic mode. I used to set to dynamic by default.
Reply 5 of 6, by Freddo
Arena isn't a protected mode game so it won't use the dynamic core by default.
Not anymore (that I noticed anyway).
But the dynamic core used to be less compatible and less stable and wouldn't work properly with Daggerfall back in 0.65 (or whatever version it was).
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
The dynamic cores have actually (way) better functionality thus providing
a better level of compatibility, still there may be timing/irq related problems
as side effects.
