Keyboard layouts
For Documentation: Userguides and howto's.
Keyboard layouts
Postby robertmo » 2009-6-02 @ 01:49
If Dosbox fails to autodetect your keyboard layout properly, try changing it by editing your dosbox configuration under [dos] section
[dos]
keyboardlayout=auto
Change "auto" to one of these values:
For example for Turkish keyboard: keyboardlayout=tr440 (This layout also allows to switch between two different layouts with leftalt-leftshift and leftalt-rightshift)
Keboard layouts built into DOSBox (layouts in brackets are the same):
Code: Select all
us103 (us), ux103 (ux)                       US, US International
dv103 (dv), lh103 (lh), rh103 (rh)           US Dvorak, Left-Hand, Right-Hand
sq448, sq452 (sq)                            Albania
hy                                           Armenia*
az                                           Azerbaijan*
by463 (bl463,by,bl)                          Belarus*
be120 (be)                                   Belgium
ba234 (ba)                                   Bosnia & Herzegovina
br274, br275 (br)                            Brazil
bg241, bg442 (bg)                            Bulgaria
ca58 (cf58,ca,cf), ca445 (cf445), cf501      Canada
hr234 (hr)                                   Croatia
cz243, cz                                    Czech Republic
dk159 (dk)                                   Denmark
ee454 (et454,ee,et)                          Estonia*
fo                                           Faroe Islands
fi153 (su153,fi,su)                          Finland
fr120, fr189 (fr)                            France
ka                                           Georgia*
de129 (gr129,de,gr), de453 (gr453)           Germany
gk220 (el220), gk319 (el319,gk,el), gk459 (el459)  Greece
hu208, hu                                    Hungary
is458 (is), is161 (is197)                    Iceland
it141 (it), it142                            Italy
kk                                           Kazakhstan*
ky                                           Kyrgyzstan*
la171 (la)                                   Latin-American-Spanish
lv, lv455                                    Latvia*
lt210, lt211, lt212 (lt), lt221, lt456       Lithuania*
mk449 (mk)                                   Macedonia
mt47 (ml47), mt (ml)                         Malta
mn (mo)                                      Mongolia*
nl143 (nl)                                   Netherlands
no155 (no)                                   Norway
ph                                           Philippines
pl214, pl457 (pl)                            Poland
po163 (po)                                   Portugal
ro333 (ro), ro446                            Romania
ru441 (ru), ru443                            Russia
sr118 (sr), sr450                            Serbia & Montenegro
sk245 (sk)                                   Slovakia
si234 (si)                                   Slovenia
es172 (sp172,es173,sp173,es,sp)              Spain
sv153 (sv)                                   Sweden
sd150 (sg150,sd,sg), sf150 (sf)              Swiss
tm                                           Turkmenistan
tr179 (tr), tr440                            Turkey
ua465 (ur465), ua (ur)                       Ukraine*
uk166 (uk), uk168                            United Kingdom
uz                                           Uzbekistan*
yu234 (yu)                                   Yugoslavia
*For some layouts you must have ten ega.cpx files (from freedos) in dosbox folder.
Codepages built into dosbox (if someone for some reason needs them):
437 United States
850 Latin-1
858 Latin-1 (with Euro sign)
852 Latin-2 (Eastern European) (with Euro sign)
853 Latin-3 (Southern European)
857 Latin-5 (Turkish) (with Euro sign)
771 Lithuanian and Russian (KBL)
772 Lithuanian and Russian
855 Cyrillic-1
872 Cyrillic-1 (with Euro sign)
866 Cyrillic-2 (Russian)
808 Cyrillic-2 (with Euro sign)
851 Greek
869 Greek (with Euro sign)
737 Greek-2
User avatar
robertmo
Return to DOSBox Guides
Who is online
