Strike Commander...
First post, by strohberries28
When sintalling this old gem it requires of me to select A: or B: to intstall from which isn't an option because the ZIP is on the hard drive, you know the whole score. How do i get past this little here problem? I SERIOUSLY want to play this game again but am stuck solidly. 😵
Reply 1 of 9, by wd
Rank DOSBox Author
DOSBox Author
Copy the files on floppies.
Reply 2 of 9, by Davros
really my strike commander came on cd ?
Reply 3 of 9, by strohberries28
If it did then obviously I got hold of the ooolder version of it. Thank goodness I still have a floppy drive. Problem is I have no I dea of knowing which files were on which floppy...or it doesn't matter? Is it a dosbox problem? And probably an old question: how do I run up the memory in dosbox cuz this seems to eat mem for breakfast.
Reply 4 of 9, by wd
Rank DOSBox Author
DOSBox Author
You didn't tell that you're (trying to) use dosbox for this.
If so you can just mount the directory as a-drive with the floppy option, check out the readme.
Reply 5 of 9, by strohberries28
You're right, I didn't. I'll most probably be back 🤣. So it won't be necessary to make individual floppies then?
Reply 6 of 9, by wd
Rank DOSBox Author
DOSBox Author
Well check if the installation works with a regular directory mounting first.
Reply 7 of 9, by strohberries28
It runs! Mounted a virtual a and the installation went smoothly. Game runs, music works. BUT, and there's always a but, the damn joystick is giving me stick. How to configure joystick? I have sidewinder pro and SC picks up the extra buttons as joystick 2.
Reply 8 of 9, by strohberries28
K never mind I sorted the joystick problemeneso real quick. Thanks for all the help! Just wish i could hear missile launches and explosions...and speech! Must look for speech pack. Also I can't remember, it being that long ago, if strike commander supported the use of throttle and rudder??
Reply 9 of 9, by Neville
There's a joystick calibration option inside the game. Press CTRL+O (or was it ALT+O?) ingame and you will be able to calibrate the joystick and tweak many other stuff.
