First post, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DOSBox's internal COPY command does not support copying all files from a source directory unless \*.* is explicitly appended to the filespec. Real DOS assumes *.* when the source filespec is a directory, and game install batch files might use this (Bram Stoker's Dracula is one I know of that does). You can, of course, work around the limitation by editing batch files, manually copying files, using the 4DOS shell, etc; but I thought it would be nice to have the feature.
It's a simple idea, but was a bit tricky to splice into the code without breaking existing functionality. All the most obvious stuff works OK as far as I can tell, including the source concatenations which gave me some trouble. Note that DOSBox supports concatenation with the "+" sign, but not with wildcards (as DOS does), and I didn't try to implement it... it's a good chance no game needs that, though. One quirky thing I ran into was DOS_FindFirst() reporting DOS_ATTR_DIRECTORY when the filespec has *.* in it, so I had to check if it's already there to avoid adding it again.
I'm sure the code could be improved, but I took the approach of trying not to change too much.
    dirwild.diff
    907 Bytes
    88 downloads
