First post, by abyss
I got the game working but with no sound. Is what I asked possible to do to get sound.
Reply 1 of 5, by lightmaster
ran setup utility? checked dosbox.com's compatibility list?
Reply 2 of 5, by abyss
I might not have made it clear enough. I'm running it without dosbox and without sound. I want to set dosbox in away so when I click setup dosbox opens and then when I close the game dosbox closes.
Reply 3 of 5, by lightmaster
then you need to create two batch files, one pointing to game's setup then another that has the exit command after playing the game..
Reply 4 of 5, by abyss
How would I do that?
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
create a shortcut to dosbox.exe and add as commandline parameters
-exit
and full path to the executable of TV
Water flows down the stream
