Tass Times in Tonetown not running correctly
Having problems with a specific game or application? Post your problems here!
Postby dfreer » 2009-6-24 @ 16:37
Been trying to get this game working for a couple days now, no dice and google has failed me. The game starts up correctly in DosBox 0.73, but the intro runs too fast (slowing down to about 350 cycles seems to work ok).
Once I hit a key to start the game, it will start to show the full screen (picture of the living room, with 8 panel action list on the right, bottom of screen containing flavor text describing the current room). After about a second with no user input, all graphics will disappear and I'm left with just the text description.
The game continues to run, as I can move from room to room using the text parser, but not being able to see the room/use the mouse to pick up items makes the game unplayable. Can anyone please help me get this game running?
MobyGames Link
dfreer
Re: Tass Times in Tonetown not running correctly
Postby DosFreak » 2009-6-24 @ 17:16
Try changing machine= in dosbox.conf
Try these one by one:
hercules, cga, tandy, pcjr, ega, vgaonly,
Game Acronym List
DosBox CVS Builds
DosBox Feature Request Thread
DosBox FAQ
PC Game Compatibility List
"People like coldplay and voted for the nazis, you can't trust people."
User avatar
DosFreak
Postby eL_PuSHeR » 2009-6-24 @ 19:37
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
User avatar
eL_PuSHeR
Moderator
Postby dfreer » 2009-7-04 @ 23:39
DosFreak wrote:Try changing machine= in dosbox.conf
I have tried each one of these, with all the same results (other than hercules which displays nothing at all but produces sound). Any other suggestions?
dfreer
Postby ripsaw8080 » 2009-7-05 @ 00:58
It's a bug in the DOS conversion of the game that isn't present in the original booter. When you press enter at an empty command prompt, it switches between full-screen text and mixed graphics/text. Just press space or some key other than enter to clear the intro screen. You can always press enter to toggle between the views, regardless. The bug is caused by the conversion seeing that a key has been pressed during the intro, but not actually reading the key, so it gets read later.
EDIT: This 1986 game supports a serial mouse, but not the PS/2-style mouse that DOSBox emulates. I think there is a way to use directserial and a real serial mouse, but not sure if it will work.
User avatar
ripsaw8080
DOSBox Author
Postby dfreer » 2009-7-13 @ 00:24
ripsaw8080 wrote:It's a bug in the DOS conversion of the game that isn't present in the original booter. When you press enter at an empty command prompt, it switches between full-screen text and mixed graphics/text. Just press space or some key other than enter to clear the intro screen. You can always press enter to toggle between the views, regardless. The bug is caused by the conversion seeing that a key has been pressed during the intro, but not actually reading the key, so it gets read later.
WOW That is indeed the problem! Can't believe that all along it was something so simple.
I've now noticed the mouse problems as well. I don't believe I still own my old serial mouse, I really hope there is another solution. But the graphics really were the main thing at least I can play the game now :D
dfreer
Postby robertmo » 2009-7-13 @ 15:46
ripsaw8080 wrote:This 1986 game supports a serial mouse, but not the PS/2-style mouse that DOSBox emulates. I think there is a way to use directserial and a real serial mouse, but not sure if it will work.
It works. You have to connect serial mouse to your com after windows has completely booted, so that it won't install drivers for this mouse.
[serial]
serial1=directserial realport:COM1 irq:4
By the way - serial mouse is very delayed in dosbox in every game/program.
User avatar
robertmo
Postby garrynichol » 2011-2-15 @ 14:54
[serial]
All I did was set the windows drivers to disable in device manager (your windows mouse won't work after that)
Also run your serial mouse driver in dosbox.config or your dosbax autoexec.bat. Then your serial mouse should work in dosbox.
I still didn't see any improvement in the mouse response though.
garrynichol
Postby Mau1wurf1977 » 2011-2-15 @ 15:55
OT but this game was released originally for the Apple. There are also C64 and Amiga versions.
Might be worth checking them out? Maybe one of the other versions is superior?
User avatar
Mau1wurf1977
Postby gumpy » 2011-6-20 @ 19:59
So it's not possible to emulate a serial mouse in DOSBOX - you have to use a real serial mouse? :exclamation:
User avatar
gumpy
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 0 guests
