First post, by archsan
First and foremost, peaceful greetings to every soul stuck in the body of Marvin.
I'm new to this forum and this is my first post in VOGONS. 😀
A Diamond Monster 3D card has just arrived today, packed inside an unassuming box. It wasn't even "box"-shaped when it came, but apparently the card's still intact. The Monster looks clean and smells... alcoholic. Still I had no choice but to test it immediately. [pic attached below]
On a faulty (for legacy/retro purpose) WinXP OS with Anthony's XP/Win2K Voodoo1 driver, i couldn't start Turok, but NFSIII ran beautifully so i can happily confirm that the Monster is working. Had to switch VGA cable though, since i don't have a pass-thru VGA cable at hand.
So, now that the Monster is here, the quest to build a full-fledged 'preservation' system goes on. I'll begin with a LEGACY/DOS machine:
target configuration:
  • unlocked Deschutes P2 _________________ just won a 350MHz FPO# 9814.. S$5 on ebay
    ABIT BH6/BE6/SOYO SY-6BA+IV (SoftBIOS)_still looking for one local
    AGP 3dfx Voodoo 3 ____________________ got it
    PCI S3 Virge (esp. Diamond S3D 2000)_____still looking for a cheap one local
    PCI Diamond Monster 3D _______________ got it (20090629)
    PCI Diamond Monster Sound MX300 ______ shipping
    ISA Creative SB 16 CT2800______________ looking for one, as suggested by Gerwin
    ISA Creative SB AWE64 Gold_____________lots on ebay, save for later
    Roland SCD-15________________________still looking for one
    Roland MT-32/CM-32L _________________ looking for 220V version while saving for it
    add: SoundBlaster Pro 1.0 CT1330 (to replace AWE64 or to put in another system😕)
That's it. I'll save some other soundcards for later (target: GUS ACE, Ensoniq Soundscape, Terratec Maestro)
What i have now is this oldcshool box i picked up for ~$35
  • Pentium III 450
    ASUS P2B rev 1.10
    320MB RAM
    IDE 20GB HDD, CD-RW, and 3.5" FDD
    AGP 3dfx Voodoo 3 2000
    ISA CT4170 SB16 Vibra
    ISA modem and PCI NIC (pulled them off)
    and now with a Monster 3D 😁
Questions so far:
1. Just to confirm--when i have this setup completed, i'd get all of these, right?
  • Roland LA, GM, GS
    AdLib/SoundBlaster
    SB Pro 8-bit stereo (with MX300)
    FM/OPL-3
    SB-16
    SB-AWE
    WSS & DirectSound
    A3D
2. How good/bad is the SB Pro emulation on MX300/Vortex2?
3. Is MX300 (or any Vortex2) + Roland SCD-15 + Roland MT-32/CM-32L a good idea?
4. Which SB16 CT model number should i get? One with the least noise and most acceptable sound quality. Won't be using it for MIDI--just OPL3 and SB16 sound. CT17xx? CT12xx? CT2xxx? CT4xxx?
5. I've read this thread (Slowing a 440BX based PC). Is there a better option for a flexible platform than an unlocked P2 with SoftBIOS (386/486 range up to ~300MHz)? Any hardware + software-slowing down combination?
Thank you for your responses!
    7.64 KiB
    I'd like a 1996-edition card, plus the original green packaging box as well. If you will sell any one of them, please PM me!
    17.6 KiB
Reply 1 of 20, by archsan
While waiting for responses (and maybe tinkering with the Monster and DOS glide game demos), here's another configuration which i will hopefully build later for a 'final' Win9x system. This is why i don't need the fastest stuff in the LEGACY/DOS machine.
target:
  • AMD 2.8GHz Athlon/LE1660
    MSI K9MM-V micro-ATX
    2GB DDR2-800
    AGP NV GF FX 5900 (maybe build another clone with V5)
    PCI DMS MX300/Aureal SQ2500
    PCI SB0350 Audigy 2 ZS gold
what i've got:
P4 2.4C
Chaintech, i865PE
1.7GB DDR-400
NV GF 7900GS
SB0090 Audigy 1
but this should be much easier for me, as it shouldn't concern the "black magic" of DOS and the jungle of VOG (speed, sound etc), so in the meanwhile...
let's get back to my LEGACY/DOS config, would u, pleease? 😊
Reply 2 of 20, by gerwin
Welcome archsan. That is some nice hardware you are gathering.
archsan wrote:
1. Just to confirm--when i have this setup completed, i'd get all of these, right? Roland LA, GM, GS / AdLib/SoundBlaster / SB Pro 8-bit stereo (with MX300) FM/OPL-3 / SB-16 / SB-AWE / WSS & DirectSound / A3D
well.. most of it should be possible. Getting one PCI soundcard next to another PCI or ISA soundcard is not a big challenge, but putting in more soundcards gets tricky.
A rough estimation; about 90% of my games/programs accept it as a SB-Pro without any issues. The OPL-3 FM is emulated, which is obvious.
Usually the waveblaster header's midi port is Hardwired to the Gameport's midi port. So this might give problems. But I don't use external modules such as an MT-32, so I have never really tried.
The CT-2800 was my choice some months ago, it ain't noisy and has an OPL-3.
That multiplier limited P-II system can potentially give you 133MHz to 400MHz (with L2 cache disabled below 200MHz). But few mainboards have the 1.5x multiplier option. Besides P-II an AMD K-6 system is also an option: Link
Reply 3 of 20, by swaaye
FYI, I'm not sure that you can run an Audigy 2 in Windows 9x. It does look like the original Audigy can be used, however.
There is no perfect setup, IMO. 😀 Part of the fun is just messing around and seeing what happens. Combinations of hardware bring nuances that are hard to predict.
Reply 4 of 20, by retro games 100
swaaye wrote:
FYI, I'm not sure that you can run an Audigy 2 in Windows 9x. Use a SBLive! or Vortex 2.
I have run an Audigy 2 ZS (with front drive bay) successfully in Windows 98, using the retail driver DVD-ROM. It's rather nice actually. You even get the option to revert back to the VxD driver package, if you don't want to use the WDM drivers.
Reply 6 of 20, by archsan
Thank you for your responses guys. I really appreciate it.
Copy that. From what i have read, VOGONS is not exact science 😐, well, at least not for me anyway. However, lots of member's experiences on the forum do help newbie like me on selecting which components to use 😀 . Or what to avoid. So i think i must do my part here (that is to put together the real things) and report back my own experience.
If it can't be done with one single box, i'm always ready to build a second one 😉 just to cover more standards. "Fun"? Yes, and i can see that the biggest reward will be the moments i share the legacy with other people (especially kids--i'm thinking of my nephews right now 😁).
Reply 7 of 20, by archsan
Now i'm thinking again about putting in an original SB Pro (CT1330). I'm only concerned that it might be difficult to find them 😖. Have some of you guys tried or managed to find one in the recent years?
Have someone else run this combination? For this system, i think of this card mostly as a MIDI header/port, like a PCI version of MPU401AT. I formed that opinion after reading (IIRC) Swaaye's thread or post somewhere on this forum. I'd like to try this myself, but i couldn't find an MT32 with an ACB-220 and the MX300 is not here yet. And i haven't even spotted a single SCD-15/SCB-55 to pick.
Copy that. thanks for the header.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 8 of 20, by archsan
5u3's systems look very interesting--no, fantastic 😲. 5u3, if you read this, have you started stocking on "spare parts" to preserve your systems? 😁 but one thing that caught my attention the most was the
5u3 wrote:
case switches for selecting system bus speed and multiplier
thing. Have you documented it somewhere else? Maybe i can stay with ASUS P2B's and use this mod instead of relying on SoftBIOS.
Reply 9 of 20, by archsan
I found this link for Win98 Hardware Compatibility List (official from Microsoft it seems). Only up to 2003 though. Audigy 2/ZS is released after that. Geforce FX and 6 series which are (were) officially supported are not on the list as well.
If you want something more updated, you may find useful info from a surviving Win9x user-base on MSFN. Try this link for general Win9x hardware compatibility and this link for latest motherboards that support/have drivers for Win98. They have been my resource for configuring my 'final' Win9x system, so i recommend the site for anyone building a new PC for Win9x.
It's DOS that i'm lost in... 😅
... but now i've found VOGONS though 😎
Reply 10 of 20, by retro games 100
archsan, thanks very much for those '98 hardware compatibility links - they were very useful. 😀
BTW, I would be cautious getting any SB16 CT17xx models (..40, ..50, ..70), because they don't sound all that great.
Reply 11 of 20, by gerwin
correction: a 2.0x multiplier is sufficient for 133MHz.
archsan wrote:
Now i'm thinking again about putting in an original SB Pro (CT1330). I'm only concerned that it might be difficult to find them S-Face. Have some of you guys tried or managed to find one in the recent years
Well there is a SBPro2 code CT1600 too, I have seen them for sale regularly. But compared to these I would rather consider a quality 16-bit ISA soundcard that is SBPro compatible. ISA soundcards have an easier job in being compatible then a PCI card, because they don't have to fake/emulate the ISA bus channels.
I measured things on my Turtle Beach Vortex-2 Card; The Waveblaster's Midi-out is connected to the Gameport's Midi-out through a 300 Ohm resistor.
Reply 12 of 20, by Malik
Just wanted to add in a few points :
1. I'm having a SB Audigy 2 ZS too, and if I'm not mistaken, the minimum OS requirement out of the box for it is Windows 98 SE.
2. SCD-15 is rare. Quite difficult to get. For GS/GM sounds, you can get a SC-55 or SC-88. Problem is, both these are not very cheap. Otherwise, the AWE64 can handle good GM/GS compatibility in real mode games. And AWE-32 with additional RAMs will do wonders though, when compared to AWE64. (I have both.) For MT-32, it's a must to get the MT-32, or LAPC-1 (another rare item) or the Roland CM-32/64/300/500 series.
3. As for the external midi/internal soundcard combo, I have in one of my systems, the LAPC-I for MT-32 sounds, and an AWE32 connected via it's midi port to my SC-55 MKII. I also have the digital out cable connected to the AWE32 for digital FM/EMU chips-sounds. Occasionally I add in a Vortex2 based card (not from Diamond) to playtest the sounds in System Shock 2 and Thief, for the Aureal sounds in Windows 9x only. My MT-32 is connected to my main (another) system to the X-Fi's I/O drive.
4. One of my classic Dos based systems is using PIII 450MHz with P3B-F mobo. A bit similar to the P2B.
Reply 13 of 20, by archsan
Hi there Malik, so we're neighbors by nation, i hope we can get along well here despite our nations' current issues... 😦 😁
Yes. Incidentally 98SE seems to be the most popular choice for people building/maintaining a Win9x system. Update this with all the available fixes, add some WinMe features (e.g., its defragger is said to be the fastest of all defraggers available for any OS) and you get the best of Win9x.
I know i can replace SCD-15 with an SC-55 or even SC-88 for GM/GS, and yes they can be expensive.
Since you have a couple of Roland external modules, i'm curious about where did you get yours from. Your country has 240V (or is it 230V) mains, isn't it? Do you get the ACB-xxx and ACI-xxx (that is suitable for your mains) included in the package when you get your MT-32 and SC-55MkII? Or do you use an additional trafo with them?
Reply 14 of 20, by archsan
gerwin wrote:
... But compared to these I would rather consider a quality 16-bit ISA soundcard that is SBPro compatible. ISA soundcards have an easier job in being compatible then a PCI card, because they don't have to fake/emulate the ISA bus channels.
You mean like the Ensoniq Soundscape or Terratec Maestro, for example? Does that mean more than 90% success rate? And what about their FM quality? I'd like to compare them all if i can.
Right, 300 ohm--um, what does that mean? I'm pretty much electronics-illiterate actually. 😁
Reply 15 of 20, by gerwin
Compare them All!? do you have any idea how many were made! that would be a very long list...
🤣 Just kidding, here is the list: ISA Soundcard Overview
Some ISA SBPro-compatible cards work with all of my 50 dos games. In real Dos that is. In a Windows 9x dosbox the compatibility is a little less perfect, but that may even be so with an actual SBPro.
It means the two connectors are 'almost' hardwired to eachother. I don't know wheter it is OK to use both connectors at the same time. In the best case the midi daughterboard and the external midi module will both respond to the cards midi signal, and then they will both play the same tune.
Reply 17 of 20, by archsan
🤣 by all i mean just the cards i mentioned: SB Pro 1.0, MX300, Soundscape, and Maestro... but it's even nicer to have someone else do the job so others (me included) can enjoy the result 😁 --no, i mean, that's so very kind of you, sir! 😏
Nicest thread there. I think i will only use SB Pro sound in Real-mode DOS. I think that's closer to what "pure" means... (i'm not that purist but still)
Then i hope the actual layout of the MX300 (which is said to be the same to Aureal's reference layout) is different to the TB Vortex2 card (for the better i hope), especially on the gameport/waveblaster header part.
swaaye wrote:
fyi, you should stay far, far away from Ensoniq Soundscape 's FM synthesis emulation. It doesn't really sound like FM synth at all.
Aye, copy that, sir! No Soundscape FM, no--far, far away... 😏
Reply 18 of 20, by 5u3
Yes, I've got backups for most of the parts - but not necessarily the same models/revisions. And of course I've got no backups for the Roland cards, I couldn't afford them at the prices those things fetch nowadays.
Those switches are very easy to make - just replace the jumpers for FSB and multiplier with switches. This mod is far from perfect though - every time I want to change the speed I have to power down the board. It sure beats fiddling with the jumpers, but a software solution would be more convenient.
I like your approach with the unlocked P2. Please report on how it works out.
Reply 19 of 20, by Malik
Hi archsan! No matter how close we are, there'll always be some people who want to make problems. On the other hand, no matter how far we are, we're connected with common interests, friend! 😁
Malaysian voltage specs is 240V @ 50Hz. I got both from Japan. They didn't come with the power adapters. I just bought the commonly available multi-volt and polar selectable adapter for each of them. Shouldn't be a problem at your place too. You need only need to supply DC 9V to each, observing the polarity. Just get the adapters from any electrical outlet.
