First post, by ripsaw8080
ripsaw8080
Offline
DOSBox Author
- DOSBox Author
Executing DOS commands generates a debug log message such as "EXEC:Parsing command line: blah". When a program shells out to COMMAND.COM to execute a command, a blank line is sometimes displayed in the debugger output view instead of the message; however, the message is always written to the log file if one is active. The blank line is displayed when a trailing carriage return is copied from the command line of COMMAND.COM into a message buffer. The trailing CR isn't always used by DOS programs, but for those cases where it is used, replacing it with a terminator in debug_gui.cpp corrects the problem:
void LOG::operator() (char const* format, ...){char buf[512];va_list msg;va_start(msg,format);vsprintf(buf,format,msg);va_end(msg);+ /* Remove carriage return if present */+ Bitu len=strlen(buf);+ if (buf[len-1]=='\r') buf[len-1]='\0';if (d_type>=LOG_MAX) return;if ((d_severity!=LOG_ERROR) && (!loggrp[d_type].enabled)) return;DEBUG_ShowMsg("%10u: %s:%s\n",cycle_count,loggrp[d_type].front,buf);}
