Q: My CD-ROM doesn't work.
A: To mount your CD-ROM in DOSBox you have to specify some additional options
when mounting the C […]
when mounting the CD-ROM.
To enable CD-ROM support (includes MSCDEX):
- mount d f:\ -t cdrom (windows)
- mount d /media/cdrom -t cdrom (linux)
In some cases you might want to use a different CD-ROM interface,
for example if CD audio does not work:
To enable SDL-support (does not include low-level CD access!):
- mount d f:\ -t cdrom -usecd 0 -noioctl
To enable ioctl access using digital audio extraction for CD audio
(windows-only, useful for Vista):
- mount d f:\ -t cdrom -ioctl_dx
To enable ioctl access using MCI for CD audio (windows-only):
- mount d f:\ -t cdrom -ioctl_mci
To force ioctl-only access (windows-only):
- mount d f:\ -t cdrom -ioctl_dio
To enable low-level aspi-support (win98 with aspi-layer installed):
- mount d f:\ -t cdrom -aspi
In the commands: - d driveletter you will get in DOSBox
- f:\ location of CD-ROM on your PC.
- 0 The number of the CD-ROM drive, reported by "mount -cd"
(note that this value is only needed when using SDL
for CD audio, otherwise it is ignored)
See also the next question: The game/application can't find its CD-ROM.
Q: The game/application can't find its CD-ROM.
A: Be sure to mount the CD-ROM with -t cdrom switch, this will enable the
MSCDEX interface required by DOS games to interface with CD-ROMs.
Also try adding the correct label (-label LABEL) to the mount command,
where LABEL is the CD-label (volume ID) of the CD-ROM.
Under Windows you can specify -ioctl, -aspi or -noioctl. Look at the
description of the mount command in Section 4 for their meaning and the
additional audio-CD related options -ioctl_dx, ioctl_mci, ioctl_dio.
Try creating a CD-ROM image (preferably CUE/BIN pair) and use the
DOSBox-internal IMGMOUNT tool to mount the image (the CUE sheet).
This enables very good low-level CD-ROM support on any operating system.
