Blood
First post, by arnold
I'm sure i have installet blood and all the things right but it dos'n work.
When i click on the glidos icon and choose blood, and start game, then after a few seconds it's says "press any key" i do that, and then it says "press a key to start blood" i do that, and then it start building up some 3d engine (see picture) and a few seconds after that it goes back to the desktop.
please help.
    53.13 KiB
Reply 1 of 13, by Glidos
I have to admit that on my XP machine a get the same problem. Luckily for me when I try again it works. I don't know what the cause is. Blood must be sensitive to something that varies each time a dos box is started.
Reply 3 of 13, by Glidos
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
D:\>cd CSPACE
D:\CSPACE>cd Games
D:\CSPACE\Games>cd Blood
D:\CSPACE\Games\Blood>dir
Volume in drive D is GAMES
Volume Serial Number is 4004-1901
Directory of D:\CSPACE\Games\Blood
06/03/2003 10:20 <DIR> .
06/03/2003 10:20 <DIR> ..
24/11/2002 12:42 31 LAUNCH.TMP
15/07/1998 14:43 438,039 ARTEDIT.EXE
04/04/1997 16:43 2,696 ARTEDIT.TXT
09/12/1994 12:13 4,427 ARTFORM.TXT
15/07/1998 14:43 277,187 B2BLUD.EXE
15/07/1998 14:43 153,354 BARF.EXE
11/08/2001 00:51 627 bld-cryp.bat
01/09/2003 23:45 5,961 BLOOD.CFG
15/07/1998 14:41 1,442,615 BLOOD.EXE
24/04/1997 21:13 2,102 BLOOD.ICO
11/02/1998 17:37 9,570,681 BLOOD.RFF
11/04/1997 11:13 45 BLOOD.URL
21/07/1998 14:19 39,605 BLOODHLP.TXT
25/03/1998 18:40 758 COMMIT.DAT
22/02/1996 22:58 25,846 COMMIT.EXE
12/08/1998 10:24 327,015 CP01.MAP
12/08/1998 10:24 295,323 CP02.MAP
12/08/1998 10:24 190,223 CP03.MAP
12/08/1998 10:24 250,535 CP04.MAP
12/08/1998 10:24 233,263 CP05.MAP
12/08/1998 10:24 234,907 CP06.MAP
12/08/1998 10:24 185,115 CP07.MAP
12/08/1998 10:24 219,087 CP08.MAP
12/08/1998 10:24 405,263 CP09.MAP
12/08/1998 10:24 1,170,729 cpart07.ar_
12/08/1998 10:24 3,335,444 cpart15.ar_
12/08/1998 10:24 95,623 CPBB01.MAP
12/08/1998 10:24 115,979 CPBB02.MAP
12/08/1998 10:24 64,987 CPBB03.MAP
12/08/1998 10:24 132,547 CPBB04.MAP
12/08/1998 10:24 110,839 CPSL.MAP
12/08/1998 10:24 11,728 CRYPTIC.EXE
10/08/2001 23:53 3,991 cryptic.ini
11/08/2001 00:50 376 cryptic.txt
20/08/1997 10:57 7,270 DEMOS.TXT
29/02/1996 08:06 265,396 DOS4GW.EXE
15/04/1997 13:53 46 DWANGO.URL
30/07/1996 13:53 94,622 EDITART.EXE
05/08/1997 12:40 5,463 EDITART.TXT
15/04/1997 14:01 46 ENGAGE.URL
15/07/1998 14:08 7,351 GUI.RFF
15/04/1997 14:10 44 HEAT.URL
15/04/1997 21:38 44 KALI.URL
10/04/1997 16:53 6,235 LICENSE.TXT
15/07/1998 14:44 920,919 MAPEDIT.EXE
15/04/1997 18:06 494 MAPEDIT.INI
09/09/1997 11:00 48,376 MAPEDIT.TXT
04/03/1997 19:49 3,847 MODEM.PCK
10/04/1997 15:45 4,594 MONOLITH.TXT
11/04/1997 12:39 44 MONOLITH.URL
15/04/1997 13:50 47 MPLAYER.URL
16/07/1998 11:48 19,786 README.TXT
13/04/1997 04:05 58 SERVICES.URL
05/08/1997 11:31 587,784 SETMAIN.EXE
18/04/1996 21:17 37,853 SETUP.EXE
15/07/1998 14:11 28,552,775 SOUNDS.RFF
21/04/1997 15:18 4,096 SURFACE.DAT
08/01/1996 00:11 8,448 TABLES.DAT
15/04/1997 13:50 43 TEN.URL
09/04/1997 13:04 1,881,007 TILES000.ART
08/04/1997 02:28 1,672,613 TILES001.ART
08/04/1997 02:28 1,001,125 TILES002.ART
15/07/1997 10:44 960,629 TILES003.ART
09/04/1997 12:10 1,647,911 TILES004.ART
21/04/1997 15:25 1,784,595 TILES005.ART
08/04/1997 02:28 1,372,029 TILES006.ART
23/07/1997 14:59 1,330,026 tiles007.art
21/07/1997 16:21 710,506 TILES008.ART
30/07/1997 17:43 1,644,888 TILES009.ART
21/07/1997 18:23 2,762,914 TILES010.ART
14/04/1997 11:42 2,062,428 TILES011.ART
12/05/1997 10:55 1,887,569 TILES012.ART
08/04/1997 02:28 1,474,846 TILES013.ART
21/04/1997 15:25 2,009,595 TILES014.ART
14/07/1997 11:17 1,811,110 tiles015.art
13/02/1998 16:03 24,574 TILES016.ART
13/02/1998 16:04 10,647 TILES017.ART
20/05/1998 18:29 24,265 UNSTALL.EXE
17/01/1997 16:37 8,192 VOXEL.DAT
18/03/1998 12:13 1,557,463 3DFX.EXE
01/09/2003 23:25 120 Blood.bat
31/08/2003 16:44 18,968 Glide2x.ovl
07/02/2003 17:22 45,056 PollPipe.dll
07/02/2003 17:22 2,829 Glidos.pif
07/10/2002 16:22 66,916 gldvesa.exe
17/02/2003 00:56 124 Glidos.bat
21/09/2002 18:22 130 NOLFB.COM
10/08/2001 23:52 12,871 blood.ini~
17/02/2003 00:52 12,871 blood.ini
06/03/2003 10:21 <DIR> TX3DFX
01/09/2003 23:45 967 Blood.PIF
90 File(s) 77,722,413 bytes
3 Dir(s) 4,840,390,656 bytes free
Reply 7 of 13, by arnold
This is the files i have, maybe you can see what is wrong.
D:\BLOOD
09-09-2003 01:52 <DIR> .
09-09-2003 01:52 <DIR> ..
09-09-2003 01:52 <DIR> TX3DFX
18-03-1998 12:13 1.557.463 3DFX.EXE
09-09-2003 01:40 5.922 BLOOD.CFG
15-07-1998 14:41 1.442.615 BLOOD.EXE
12-05-2001 23:02 13.231 BLOOD.INI
11-02-1998 17:37 9.570.681 BLOOD.RFF
11-04-1997 11:13 45 BLOOD.URL
21-07-1998 14:27 77.521 BLOOD000.DEM
21-07-1998 14:46 50.461 BLOOD001.DEM
21-07-1998 14:50 72.923 BLOOD002.DEM
21-07-1998 14:53 65.333 BLOOD003.DEM
21-07-1998 14:19 39.605 BLOODHLP.TXT
25-03-1998 18:40 758 COMMIT.DAT
22-02-1996 22:58 25.846 COMMIT.EXE
12-08-1998 10:24 327.015 CP01.MAP
12-08-1998 10:24 295.323 CP02.MAP
12-08-1998 10:24 190.223 CP03.MAP
12-08-1998 10:24 250.535 CP04.MAP
12-08-1998 10:24 233.263 CP05.MAP
12-08-1998 10:24 234.907 CP06.MAP
12-08-1998 10:24 185.115 CP07.MAP
12-08-1998 10:24 219.087 CP08.MAP
12-08-1998 10:24 405.263 CP09.MAP
12-08-1998 10:24 1.170.729 CPART07.AR_
12-08-1998 10:24 3.335.444 CPART15.AR_
12-08-1998 10:24 95.623 CPBB01.MAP
12-08-1998 10:24 115.979 CPBB02.MAP
12-08-1998 10:24 64.987 CPBB03.MAP
12-08-1998 10:24 132.547 CPBB04.MAP
12-08-1998 10:24 110.839 CPSL.MAP
12-05-2001 22:55 11.728 CRYPTIC.EXE
12-08-1998 10:24 4.035 CRYPTIC.INI
12-08-1998 10:24 1.331.452 CRYPTIC.SMK
12-08-1998 10:24 1.036.332 CRYPTIC.WAV
29-02-1996 08:06 265.396 DOS4GW.EXE
15-04-1997 13:53 46 DWANGO.URL
15-04-1997 14:01 46 ENGAGE.URL
06-09-2003 19:09 25.756 Glide2x.ovl
09-09-2003 16:28 124 Glidos.bat
06-09-2003 19:09 2.829 Glidos.pif
15-07-1998 14:08 7.351 GUI.RFF
15-04-1997 14:10 44 HEAT.URL
15-04-1997 21:38 44 KALI.URL
10-04-1997 16:53 6.235 LICENSE.TXT
04-03-1997 19:49 3.847 MODEM.PCK
10-04-1997 15:45 4.594 MONOLITH.TXT
11-04-1997 12:39 44 MONOLITH.URL
15-04-1997 13:50 47 MPLAYER.URL
21-09-2002 18:23 1.988 NOLFB.ASM
21-09-2002 18:22 130 NOLFB.COM
06-09-2003 19:09 45.056 PollPipe.dll
05-09-2003 03:28 3.576.708 R0020.EXE
05-09-2003 03:35 1.350.417 R1120.EXE
16-07-1998 11:48 19.786 README.TXT
13-04-1997 04:05 58 SERVICES.URL
05-08-1997 11:31 587.784 SETMAIN.EXE
18-04-1996 21:17 37.853 SETUP.EXE
12-05-2001 22:58 968 Setup.PIF
15-07-1998 14:11 28.552.775 SOUNDS.RFF
21-04-1997 15:18 4.096 SURFACE.DAT
08-01-1996 00:11 8.448 TABLES.DAT
15-04-1997 13:50 43 TEN.URL
09-04-1997 13:04 1.881.007 TILES000.ART
08-04-1997 02:28 1.672.613 TILES001.ART
08-04-1997 02:28 1.001.125 TILES002.ART
15-07-1997 10:44 960.629 TILES003.ART
09-04-1997 12:10 1.647.911 TILES004.ART
21-04-1997 15:25 1.784.595 TILES005.ART
08-04-1997 02:28 1.372.029 TILES006.ART
23-07-1997 14:59 1.330.026 TILES007.ART
21-07-1997 16:21 710.506 TILES008.ART
30-07-1997 17:43 1.644.888 TILES009.ART
21-07-1997 18:23 2.762.914 TILES010.ART
14-04-1997 11:42 2.062.428 TILES011.ART
12-05-1997 10:55 1.887.569 TILES012.ART
08-04-1997 02:28 1.474.846 TILES013.ART
21-04-1997 15:25 2.009.595 TILES014.ART
14-07-1997 11:17 1.811.110 TILES015.ART
13-02-1998 16:03 24.574 TILES016.ART
13-02-1998 16:04 10.647 TILES017.ART
21-12-1997 00:20 99.444 UHARC.EXE
13-05-2001 00:02 238 unpack.bat
20-05-1998 18:29 24.265 UNSTALL.EXE
17-01-1997 16:37 8.192 VOXEL.DAT
When i run the game it makes the TX3DFX directory.
Tomb Raider 1 and Unfinished Business works fine.
Reply 10 of 13, by Glidos
You would know if you were, becaus you would have downloaded it from the net. So I guess you are not. Might be worth grabbing it, because it is a version that is known to work for some people.
