First post, by mrkaki
Earlier today I noticed I still have the Shadow Warrior CD, so I installed it, installed the patches and tried running it - everything worked fine but in an unplayable FPS.
So I tried using DOSBOX and almost everything works fine with a very playable FPS, but there's only one problem, a big one: I'm missing the music.
The sound works fine. I emulated the sound driver Sound Blaster Pro 2.0 with the IRQ at 7, 8-bit DMA at 1 and 16-bit DMA at 5.
Can I fix this problem? Ifso, how?
