First post, by jal
I've compiled dosbox sources for years now, and never had any problems. 0.73 compiles and runs fine on my Ubuntu desktop (debug build) - so far so good. However, since I've recently put Ubuntu (eeebunto to be exact) on my EeePC 900, I thought I'd make it a development machine as well. The problem I'm having on the laptop now is the following:
- running a build of 0.73 with --debug-enabled fails (see below)
- running a copied build of 0.73 from my desktop fails with same behaviour
with "fails" I mean the following:
- First time seems to start OK, after the splash screen I get a prompt. However, after a while (+/- 30 seconds) it crashes with 'segmentation fault'.
- Starting it again results directly in segmentation fault.
- When I remove the autogenerated config file, behaviour of 'first time' above appears again (i.e. no direct crash).
- Starting it a few times results in a few segmentation faults, but then may result in the message "E: pstream.c: Assertion 'p->io == io' failed at pulsector/pstream.c:211, function to io_callback(). Aborting." or "E: mainloop.c: Assertion '!e->dead' failed at pulse/mainloop.c:285, function mainloop_defer_enable(). Aborting."
I've played around with various output, machine and core settings, but that doesn't change the behaviour. Any thoughts on what I can check to see where the fault lies?
JAL
Reply 2 of 33, by jal
while it's always a good idea to kill pulseaudio, that didn't resolve it, unfortunately (on my desktop I've still got pulseaudio running, and no problem there). haven't got the abort messages though, just the segfaults. no log in the log file, no other messages.
drives me crazy...
JAL
Reply 3 of 33, by MiniMax
Rank Moderator
Moderator
Would it help if you ran dosbox from inside gdb (or whatever debugger you prefer)?
_________________
Reply 4 of 33, by jal
I'll give it a try tonight, see what it comes up with.
JAL
Reply 5 of 33, by jal
Mmm, nothing I can go on. I'm not very versed with gdb, and I don't feel like debugging the entire dosbox, but this is some output from a few startups:
[New Thread 0xb5bc7b90 (LWP 4163)]om config file /home/kilian/.dosbox/dosbox-0.7
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb77ed6e0 (LWP 4159)]
0xb7b5bdfb in fputs () from /lib/tls/i686/cmov/libc.so.6
(gdb)
[New Thread 0xb5bcdb90 (LWP 4383)]om config file /home/kilian/.dosbox/dosbox-0.7
[Switching to Thread 0xb77f36e0 (LWP 4379)]
0xb7d30b25 in std::string::compare () from /usr/lib/libstdc++.so.6
(gdb)
[New Thread 0xb5c56b90 (LWP 4391)]om config file /home/kilian/.dosbox/dosbox-0.7
[Switching to Thread 0xb787c6e0 (LWP 4387)]
0xb7db9b25 in std::string::compare () from /usr/lib/libstdc++.so.6
(gdb)
[New Thread 0xb56d6b90 (LWP 4439)]ration.
[Switching to Thread 0xb56d6b90 (LWP 4439)]
0xb791e415 in snd_pcm_poll_descriptors_revents () from /usr/lib/libasound.so.2
(gdb)
JAL
Reply 8 of 33, by Qbix
Rank DOSBox Author
DOSBox Author
and maybe some debug symbols to dosbox
CXXFLAGS=" -O0 -ggdb3" ./configure --enable-debug
or change the -O0 with -O2 and/or go for heavy debug stuff
this makes the backtraces (bt) contain more useful information
Water flows down the stream
Reply 9 of 33, by MiniMax
Rank Moderator
Moderator
h-a-l-9000 wrote:
bt
I believe this rather cryptic post means that if you give the command bt to gbd you will get a backtrace (stacktrace) with information about where the program crashed.
_________________
Reply 11 of 33, by jal
Ok, thank's y'all, I'll try to do some more debugging tonight, if I can find the time (going on holiday this weekend, and there's unfortunately more to it than preparing your laptop for uninterrupted coding 😀).
JAL
Reply 12 of 33, by HunterZ
Actually it's the most non-cryptic way of sharing information imo, props to hal 😉
Actually it was pretty cryptic.
Reply 14 of 33, by jal
Running bt (thanks wd 😀) gives the following results for a couple of crashes:
#0  0xb7a9a078 in strcmp () from /lib/tls/i686/cmov/libc.so.6
#1 0x0815e5c3 in MAPPER_AddHandler (handler=0x80e0230 <DEBUG_Enable(bool)>, key=MK_pause, mods=2, eventname=0x823caf7 "debugger", buttonname=0x823caee "Debugger")
at sdl_mapper.cpp:2076
#2 0x080e01c1 in DEBUG_Init (sec=0xa93d0e8) at debug.cpp:1976
#3 0x0821bdc9 in Section::ExecuteInit (this=0xa93d0e8, initall=true) at setup.cpp:728
#4 0x0821be1b in Config::Init (this=0xbfd771c8) at setup.cpp:712
#5 0x0815c642 in main (argc=Cannot access memory at address 0x6e
) at sdlmain.cpp:1807
#0 0xb7bdeb25 in std::string::compare () from /usr/lib/libstdc++.so.6
#1 0x082199f9 in MSG_Add (_name=0x8240d34 "PROGRAM_MOUNT_CDROMS_FOUND", _val=0x8240d22 "CDROMs found: %d\n") at /usr/include/c++/4.3/bits/basic_string.h:2189
#2 0x080f3f7a in DOS_SetupPrograms () at dos_programs.cpp:1343
#3 0x080e6c25 in DOS_Init (sec=0xbbf7c18) at dos.cpp:1127
#4 0x0821bdc9 in Section::ExecuteInit (this=0xbbf7c18, initall=true) at setup.cpp:728
#5 0x0821be1b in Config::Init (this=0xbf903d58) at setup.cpp:712
#6 0x0815c642 in main (argc=Cannot access memory at address 0x11
The first one is from a crash after removing the config file, happening after a number of seconds, the second one repeats after that.
So it seems there's some SDL problem, probably?
JAL
Reply 16 of 33, by HunterZ
wd wrote:
A two-character string can't be THAT hard to decrypt.
Indeed, but decrypting it into the right thing requires something additional :p
BitTorrent...no
British Telecom...no
Profit!
Turns out it's all about context. Didn't realize that it was in reference specifically to gdb.
Reply 17 of 33, by wd
Rank DOSBox Author
DOSBox Author
Running bt (thanks wd)
I'm innocent, hal's the one!
BitTorrent...no British Telecom...no ??? Profit! […]
BitTorrent...no
Profit!
Ok you'll maybe even get a prize for decrypting "bt" into "Profit" 😀
Maybe you can put some LOG_MSGs into the MSG_Add in messages.cpp
