First post, by Sinner
Hello,
First and for most, I realize that dosbox was never intended to run or support windows 95. I have, however, setup bochs and created a windows 95 image from my original install cd and have Windows 95 working beautifully on dosbox 0.73. I am, however stuck with 640x480 resolutions. I have googled around and heard of some success with the latest win95 S3 drivers but I can't seem to find a place to download them.
Does anyone know where I can find video drivers for windows 95 that "might" work under dosbox?
Reply 1 of 2, by DosFreak
Use the following in dosbox.conf:
cputype=pentium_slow
core=dynamic
Do not use the video drivers that come with Windows use the attached video driver.
Don't ask for crazy stuff like D3D/hostfilesystem access/CD Drive access unless you are up to the task of coding it yourself.
    w9521103.zip
    166.53 KiB
    855 downloads
Make your games work offline
Reply 2 of 2, by Sinner
DosFreak wrote:
Use the following in dosbox.conf: cputype=pentium_slow core=dynamic […]
core=dynamic
Thank you, the driver worked great. However, setting the core to dynamic crashes for me but it runs fine on normal.
