Hi, ...
I try "DosBox PortableApps package", inside VirtualBox, with Windows XP SP3 Pro x32, VirtualBox video driver.
Inside Windows XP SP3 x32 VirtualMachine = i set max "800x600" video mode, inside DosBox i set fullscreen "original".
When i press Alt-Enter, inside The Windows xp Virtual machine, it try to go to = 1024x768-8 (8 bit color). = Then i see like the file included, ...
Then on my real Windows 7 RC x64, "HP w1858 Vga enabled 1366x768-32 16:9, have a natif video mode of 1366x768-32. I just try to set the video mode to 1024x768-32. It not fix the problem.
I will test an other LCD Screen "Samsung Vga 17 inch. 4:3" With that test = I will see if it's that "Lcd HP w1858" Lcd scren or inside the computer, ...
Sylvain St-Amand (sst)
