First post, by cyberaxe
- Newbie
I using the same settings as i do for 0.72 and previous versions but on 0.73 i dont have as much free covnentional memory
on 0.72 i have 623k free
on 0.73 i have 372k free
my mem settings are
xms=true
ems=true
umb=max
everything i load in the autoexec area is loaded with lh, since the mem command on dosbox doesnt seem to allow listing of memory usage i cant see what is actually using the memory
Memory and Autoexec Area from 0.72
[dos]# xms -- Enable XMS support.# ems -- Enable EMS support.# umb -- Enable UMB support.# keyboardlayout -- Language code of the keyboard layout (or none).xms=trueems=trueumb=truekeyboardlayout=none[ipx]# ipx -- Enable ipx over UDP/IP emulation.ipx=false[autoexec]# Lines in this section will be run at startup.@echo offSET DOSBOXD1=D:\Games\GeneralSET DOSBOXD2=GameFiles\DOSBoxSET GAMEFLDR="%DOSBOXD1% %DOSBOXD2%\GAMES"SET DWFLDR="%DOSBOXD1% %DOSBOXD2%\GAMES\DW"SET DW2FLDR="%DOSBOXD1% %DOSBOXD2%\GAMES\DW2"SET STFUFLDR="%DOSBOXD1% %DOSBOXD2%\GAMES\STTNG"SET TOONSTRK="%DOSBOXD1% %DOSBOXD2%\GAMES\TOONSTRK\Data"SET GAMES=C:\GAMES\SET CD1="I:\"SET CD2="G:\"REM MOUNT A "D:\Emulation\Computer Software\PC\DOSBox\DOS\Extra\Win3x\Drivers\Graphics\S3" -floppyMOUNT C "%DOSBOXD1% %DOSBOXD2%" -freesize 1024MOUNT D %CD1% -t cdrom -usecd 0MOUNT E "%DOSBOXD1% %DOSBOXD2%" -t cdromMOUNT F "%DOSBOXD1% %DOSBOXD2%\GAMES" -t cdromREM MOUNT G %DWFLDR%REM MOUNT G %DW2FLDR%REM MOUNT G %STFUFLDR%C:CD\CLSSET DOS32A=C:\DOS\EXTRA\DOS32ASET WINDIR=C:\WINDOWSSET PATH=%PATH%;%DOS32A%;C:\DOS\EXTRA\CTMOUSE;c:\DOS\EXTRA\SDD;C:\DOS;C:\DOS\EXTRA\Batch;C:\DOS\EXTRA\Batch\Games;C:\DOS\EXTRA\ULTRASND\WINDOWS;C:\Windows;C:\DOS\EXTRA;C:\GAMES\X-COM\TRAINER\;C:\DOS\EXTRA\DPMISET TEMP=C:\DOS\TEMPSET TMP=C:\DOS\TEMPSET DIRCMD=/wCOPY /-Y %DOS32A%\BINW\DOS32A.exe %DOS32A%\DOS4GW.exeC:CD\CD DOS\TEMPDEL /Q *.*CD\CLSREM @echo.REM @echo --------------REM @echo SB16 DriversREM @echo --------------SET SOUND=C:\DOS\EXTRA\SB16SET BLASTER=A220 I5 D1 H5 T6
REM SET MIDI=SYNTH:4 MAP:EREM @echo.REM @echo ---------------------------REM @echo Gravis Ultrasound DriversREM @echo ---------------------------SET ULTRASND=240,1,1,5,5SET ULTRADIR=C:\DOS\EXTRA\ULTRASNDREM LH C:\DOS\EXTRA\ULTRASND\ULTRINIT.EXEREM LH C:\DOS\EXTRA\ULTRASND\ULTRAMID.EXEREM @echo.REM @echo ---------------REM @echo MiscellaneousREM @echo ---------------REM LH SETVERREM LH NOLFB.COMLH XKEYB UKMOUSE /ULH CTMOUSE /P /3 /NREM @echo.REM @echo -----------------REM @echo UniVESA DriversREM @echo -----------------LH UNIVBE@echo.del /q *.swpCLS
Mem and Autoexec Area from 0.73 (slightly modified)
[dos]# xms: Enable XMS support.# ems: Enable EMS support.# umb: Enable UMB support.# keyboardlayout: Language code of the keyboard layout (or none).xms=trueems=trueumb=maxkeyboardlayout=uk[ipx]# ipx: Enable ipx over UDP/IP emulation.ipx=false[autoexec]# Lines in this section will be run at startup.@echo offSET DOSBOXD1=D:\Games\GeneralSET DOSBOXD2=GameFiles\DOSBoxSET GAMEFLDR="%DOSBOXD1% %DOSBOXD2%\GAMES"SET DWFLDR="%DOSBOXD1% %DOSBOXD2%\GAMES\DW"SET DW2FLDR="%DOSBOXD1% %DOSBOXD2%\GAMES\DW2"SET STFUFLDR="%DOSBOXD1% %DOSBOXD2%\GAMES\STTNG"SET TOONSTRK="%DOSBOXD1% %DOSBOXD2%\GAMES\TOONSTRK\Data"SET GAMES=C:\GAMES\SET CD1="I:\"SET CD2="G:\"REM MOUNT A "D:\Emulation\Computer Software\PC\DOSBox\DOS\Extra\Win3x\Drivers\Graphics\S3" -floppyMOUNT C "%DOSBOXD1% %DOSBOXD2%" -freesize 1024MOUNT D %CD1% -t cdrom -usecd 0MOUNT E "%DOSBOXD1% %DOSBOXD2%" -t cdromMOUNT F "%DOSBOXD1% %DOSBOXD2%\GAMES" -t cdromREM MOUNT G %DWFLDR%REM MOUNT G %DW2FLDR%REM MOUNT G %STFUFLDR%C:CD\CLSSET DOS32A=C:\DOS\EXTRA\DOS32ASET WINDIR=C:\WINDOWSSET PATH=%PATH%;%DOS32A%;C:\DOS\EXTRA\CTMOUSE;c:\DOS\EXTRA\SDD;C:\DOS;C:\DOS\EXTRA\Batch;C:\DOS\EXTRA\Batch\Games;C:\DOS\EXTRA\ULTRASND\WINDOWS;C:\Windows;C:\DOS\EXTRA;C:\GAMES\X-COM\TRAINER\;C:\DOS\EXTRA\DPMISET TEMP=C:\DOS\TEMPSET TMP=C:\DOS\TEMPSET DIRCMD=/wCOPY /-Y %DOS32A%\BINW\DOS32A.exe %DOS32A%\DOS4GW.exeC:CD\CD DOS\TEMPDEL /Q *.*CD\CLSREM @echo.REM @echo --------------REM @echo SB16 DriversREM @echo --------------SET SOUND=C:\DOS\EXTRA\SB16SET BLASTER=A220 I5 D1 H5 T6
REM SET MIDI=SYNTH:4 MAP:EREM @echo.REM @echo ---------------------------REM @echo Gravis Ultrasound DriversREM @echo ---------------------------SET ULTRASND=240,1,1,5,5SET ULTRADIR=C:\DOS\EXTRA\ULTRASNDREM LH C:\DOS\EXTRA\ULTRASND\ULTRINIT.EXEREM LH C:\DOS\EXTRA\ULTRASND\ULTRAMID.EXEREM @echo.REM @echo ---------------REM @echo MiscellaneousREM @echo ---------------REM LH SETVERREM LH NOLFB.COMREM LH XKEYB UKREM MOUSE /UREM LH CTMOUSE /P /3 /NREM @echo.REM @echo -----------------REM @echo UniVESA DriversREM @echo -----------------LH UNIVBE@echo.del /q *.swpCLS
Any help would be appreciated, thanks.
