First post, by tatt
I have some old dos configuration software for my line of work. It is used to connect via serail port to a piece of equipment for configuration.
My other software works fine but this particular software appears to do a check of the operating system and errors out staing that the operating system is incompatible. The exact message is......
"Running from floppy of network drive, or non-compatible operating system. DEMONSTRATION MODE ONLY. Press ESC."
Im sure that the running from floppy or network drive part is not the issue. I have mounted directly the program folder as C: and get the same error.
Here is an outtake from the progs help file.......
"This program will work in fully functional mode if it is run from drive C on any computer running the following operating systems...
DOS.
WINDOWS 95.
WINDOWS 98.
Is there any way to force DOSBOX to announce itself as DOS so I can get this software to run.
Thanks in advance.
Chris
Reply 1 of 10, by wd
Rank DOSBox Author
DOSBox Author
There is no "disable reporting as non-compatible operating system" flag.
Reply 2 of 10, by tatt
does dosbox report istelf as dos then ???
Reply 3 of 10, by tatt
The non-compatible operating system messgae is generated by our software, not dosbox!
Reply 5 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
we could probably modify dosbox so that your software detects it as dos compatible.
but as it isn't a game, I doubt that there is much incentive to do this
Water flows down the stream
Reply 6 of 10, by wd
Rank DOSBox Author
DOSBox Author
Well he didn't even post the dosbox version. Or ANYTHING of use to analyze the problem.
Reply 7 of 10, by tatt
Version is 0.73 downloaded toady.
What else do you need to know. As decribed above is as far as I can get. 😕
Reply 8 of 10, by wd
Rank DOSBox Author
DOSBox Author
mountings, how you installed the app
Reply 9 of 10, by MiniMax
Rank Moderator
Moderator
It could be that said software expects DOS 6.22 and incorrectly refuses to accept 5.00 (which is what DOSBox pretends to run) as a valid OS.
Check the README file for details on the VER command.
_________________
Reply 10 of 10, by tatt
FIXED.
Thanks all.
"ver set 6 22" this fixed the incompatible operating system part but would not run still.
Fixed this also by creating and formatting a hdd image then copying all my software here.
Thanks
Chris
