First post, by Angelusmort
Ok, I downloaded Dosbox 0.73 for windows. I managed to set up all the necessary file location paths, but when I went to run my game (Mechwarrior 2), it responded "This program cannot be run in DOS mode." Everything else seems to be working ok, It just will not run the file. It is an application (.exe) file, and yes...I am using Vista. Is there anything that I can do inside of the DOSbox shell, or do I need to download some other file? Seriously, I'm dying to play Mechwarrior again. If you have any tips that could help me they would be greatly appreciated!!!!
